Air pressure in Fox...
[Closed] Air pressure in Fox 36 Float
What air pressure is everyone running in their Floats??
I'm 185lbs and it suggests around 60psi. To complicate matters I've lowered them from 160mm travel down to 100mm, does the air pressure change? Can't get my head around whether it should or not.
Bascially, what's the best way to tune them to your weight?
Posted : 07/06/2011 4:30 pm
Sag...generally between 20-30% of whatever travel your running, or go for a ride and fiddle with a pump til they feel good
Posted : 07/06/2011 6:12 pm
Me, 90kg and 70psi. Mate of mine is 110kg and uses 88psi.
Posted : 07/06/2011 6:18 pm
Will do that sag thing, seems to be running through a lot of travel quite easily at the moment.
Posted : 07/06/2011 7:31 pm
Try here,
http://www.mojo.co.uk/sagsetup.html
Posted : 07/06/2011 7:37 pm
 mboy
Kinda what I found on my 07 Float 36's. They can blow through travel easily, then the last 30mm (on mine at least) they just stop, it's like they've got the worlds most solid bottom out bumper in them! Don't think I've ever had more than about 132mm of travel out of them...
You got R's or RC2's? I found on my RC2's running more low speed compression damping than I was expecting to helped stop them blowing through the travel as much.
Posted : 07/06/2011 7:40 pm
RC2s - will be gutted if I only get 132mm of travel as they are wound down to 100mm ๐Ÿ˜‰
Posted : 07/06/2011 7:46 pm
 mboy
LOL
What year?
Can you get the last 30mm of travel at all on yours?
Posted : 07/06/2011 8:19 pm
They're 2010s and not tried yet to get the last 30mm, will see what I can do though
Posted : 07/06/2011 9:42 pm
Chucked in about 95psi and getting sag of around 20% now.
Read on other forums that people are running them with like 40-50psi in them and finding them working OK! ๐Ÿ˜ฏ
Posted : 08/06/2011 6:26 pm
