Air compressor for ...
[Closed] Air compressor for tubeless, what do I want?
All sorts availabe, what flow rate / tank size? Any recomendation where I can just go and buy VFM one in North West Midlands?
Posted : 22/10/2009 8:27 am
6ltr tank/£60 is fine and fairly portable.
Posted : 22/10/2009 8:28 am
one from Aldi is good value and works well
Posted : 22/10/2009 8:29 am
theres a screwfix up the road, £100 a bit too much. How much is the Aldi one?
[url] http://www.screwfix.com/prods/88998/Power-Tools/Compressors/Sumo-1-5hp-6Ltr-Compressor [/url]
Posted : 22/10/2009 8:35 am
A track pump and elbow grease?
Posted : 22/10/2009 8:39 am
when they are in stock about 60 notes
Posted : 22/10/2009 8:42 am
Snaped the head off my track pump by dropping wheel on it, and after using a compressor on holiday I just want one for 4 bikes and a 3 wheeled offroad pram and lots of thorns and tyre changes.
Posted : 22/10/2009 8:52 am
I bought a used 20ltr tank jobby many years ago for a small paint spraying task.
it didn't get a whole lot of use after that but now I'm biking it's remarkably useful for all sorts of jobs (cleaning all sorts of stuff of dust, removing grips, tyres, etc). If you have tricky tyres to inflate the larger tank can be helpful but not absolutely necessary.
I'd go as cheap as poss but with a reasonable size tank (6ltr +)
Posted : 22/10/2009 9:18 am
I tried 5 times, with my large track pump, to inflate my folding tyres as tubeless - no ball was played. Took a forecourt compressor to sort it. Why waste £25 on a track pump when twice that will get you something that'll do stacks more?
Posted : 22/10/2009 9:21 am
 br
I bought a cheap compressor from Screwfix (it was £80 along with an accessory kit) when I went tubeless, works a treat. Although I did buy a better quality inflator - lock's on better along with good gauge.
http://www.screwfix.com/prods/88444/Power-Tools/Air-Tools/Metabo-RF363-Tyre-Inflator
Its worth getting hold of a Mavic tubeless valve as it comes with a screw-on bit to convert presta to schrader - as I couldn't get a presta head anywhere.
Posted : 22/10/2009 10:35 am
£10.98 for a Track-Pump from Asda.
Press on the tyre around the Valve to effect a temporary seat.
Job done. Ok so a bit of pumping is involved but they soon go up & stop leaking (loads).
And I was using the Pikey cut-in-half BMX tube system.
Where in the "North West Midlands" are you ?
Posted : 22/10/2009 11:08 am
