Anyone have any idea if i can upgrade my Vistalight bulbs for some that i saw in Lidl's (or Ikea, B&Q's, Homebase etc) for £2- they look the same. I want to swap one of my 5W spread beams for a 25W cheap bulb. Will they get too hot? Will they kill batteries?
Anyone tried it- share the knowledge please!!!
if they're MR11 (and your vistas are same as mine) then they'll fit
BUT
25W 6 volt - are you sure ?
What's the beam angle - if it's over about 20 degrees might not be great
25W isn't going to last long with your batteries (and I suppose they may not like driving something that hard ???)
I've used 10 and 15W ones that were OK - even vista used to do 15W ones. Also the vista "HOT" bulbs are actually overvolted (theyr'e a 5volt bulb that's overvolted by the 6v battery) so are brighter than a true 5W 6v bulb
[url= http://www.reflectalite.com/halogenpage.html ]these SHOULD work - bottom of page[/url]
Thanks for the info! I was going to give it a go- i tried the 5w with the 15w, and im getting about an hour on the 15w (hour and half on the 5w). So yeah youre right- a 25w bulb would kill the battery, i might give it a go anyway as the bulb costs £2!
Watch this space.....
What about these, not going to sap the battery. Ok not sure about beam spread but as you say worth a go for the money.
http://www.amazon.co.uk/Halogen-Bulb-Mr11-Bulbs-Pack/dp/B000OS8Y9M
The ones in DIY stores will more than likely be 12v domestic lamps.
