advice on gearing s...
[Closed] advice on gearing set up for lynskey cooper cx build.
[#3453714]
got one on order for the new year and thinking of putting an xtr med rear mech on the rear to run a higher ratio.. anyone done something similar?
Posted : 12/12/2011 6:48 pm
Depends on your intended usage...?
If used for winter training, CX type rides, some light trail work then CX gearing will be fine i.e. 38/46 or similar up front and 12-25 or 12-28 or so out back.
If you plan to ride it more as a mountain bike then a 32 cassette on the rear may be useful, but the gaps between the ratios is very noticeable.
Posted : 12/12/2011 7:21 pm
cheers, going to use it as an all rounder really, i have a daily commute of 40miles with 2 killer hills so need something that will make that easier
Posted : 12/12/2011 8:08 pm
