advice needed: clic...
[Closed] advice needed: clicking noise driving me mad.
So my HT has been making a clicking noise for a while now. It starts after a few kms into a ride and seems to get more frequent with time during the ride and is really noticeable if I stand and give it some welly, like when you accelerate hard or go up a hill.
Initial thoughts were; oh bugger the CSU needs replacing again as it made a similar noise which was diagnosed as a crown/stanchion joint debonding and this could be replicated by dropping the fork out and pulling on the lowers with the steerer in the bike stand. SRAM did this replacement via warranty but of course, this has now lapsed.
However, this time, there is no noise when this test is performed. The stem and bars have been cleaned and put back on. The LBS has checked the crown race and re-greased this and the headset.
Anyone got any ideas and of course the main question, will I die as a result?!
Cheers.
Posted : 13/08/2015 9:26 am
Pedals - remove - lube threads - re-fit / re torque correctly. Worked on mine yesterday.
Posted : 13/08/2015 9:45 am
Tighten cranks and chainring bolts too, then bb
Posted : 13/08/2015 9:48 am
I was getting something similar - there was a thread on here recently where the suggestion was made that it might be a dry QR skewer. I checked mine, added some grease and the clicking was no more!
Yes you will die. You will be instantly reborn as a zen master who knows all the answers. Maybe.
Posted : 13/08/2015 9:50 am
What kind of bottom bracket do you have?
If it's press fit, you have found your answer.
Posted : 13/08/2015 9:51 am
It's a sensible external XT BB.
The noise does seem to be from the front of the bike although since I'm half deaf, I could be mistaken.
Posted : 13/08/2015 10:02 am
Seeing as it occurs when you put the power down my thoughts are to check the pedals by taking them apart at the axle and greasing and tightening, I had this with my Nukeproof flat pedals a few weeks ago.
The other thing is possibly the bb, mine has gone on the single speed and makes a creaking noise under load, this is also a standard external threaded model.
Posted : 13/08/2015 10:30 am
Faceplate bolts.
Posted : 13/08/2015 10:42 am
You have crickets. Try easting more Vit C.
Posted : 13/08/2015 10:44 am
Faceplate bolts.
I have just bought a new stem so will try that. Failing this, I will try the pedal route and then the QR skewer as suggested.
Thanks to all for the pointers.
Posted : 13/08/2015 10:45 am
I had it once on my old Charge Grater commuter bike. Spent about half an hour playing about with it, got frustrated and bought a new bike. Not the best solution but it fixed it. I can't afford to do things like that now I have a family.
Posted : 13/08/2015 10:55 am
Then check the freewheel pawls for grease. Can cause a really irritating, intermittent creak/click depending on how wet/dry the ride is.
Posted : 13/08/2015 11:44 am
 SiB
Had the same problem for the last 12 months now, it was making me ride slower as the clicking was so annoying, was going to get rid of frame and start again. Like yours it was OK at beginning of ride and gradually got worse, drove me nuts!! This morning over breakfast it occurred to me that the only part of bike I have not replaced then checked for clicking noises was the rear QR skewer........BINGO!! I also noticed that the spring on the skewer had become firmly wedged in the nut side (as opposed to the closing mech side) so this was put back in to position and joys of joys, a silent bike!!
Posted : 13/08/2015 2:21 pm
Worn Time cleats on shimano flat sole shoes give a click/ creak too......I could swap them for new but they're not worn out so just switch of from the tick tick tick.....
Posted : 13/08/2015 3:24 pm
