Advice from wheels ...
[Closed] Advice from wheels builders who've used Hope BULB spidered hubs
Hi,
Anyone built with Bulb hubs that use the spider rather than the 6 bolt standard? Just wondering if the spoke lengths come out any different between the two or if the flange dimensions etc are the same.
Basically, if I take apart a spidered wheel, will the spokes be the right size to build back up into the 6 bolt version?
Cheers.
Posted : 10/10/2009 3:42 pm
Dont know, but Ive always thought you were best off using new spokes for a new wheel build.
There only about £14 or so for a wheels worth
Posted : 10/10/2009 3:48 pm
double tap
Posted : 10/10/2009 4:34 pm
The reason I ask is because I'm getting some Hope Hoops but I want to swap the rims and spokes over onto my old Bulb hubs with spiders as i already have discs and they come with a lovely Ti freehub body. Just wondering if the spokes will go over or if they need a different length. I'm just trying to compare the hubs on the Dt and wheelpro spoke calculators. They both list a BULB hub but make no distinction between spidered or 6 bolt version (if that makes sense)
Posted : 10/10/2009 4:35 pm
Cant you just remove 1 drive and 1 non drive side spoke and check? I'd measure up but only my front bulb hub is splined the rear is 6 bolt.
Posted : 10/10/2009 5:23 pm
I guess I could measure up a pair but wondered if anyone knew.
Posted : 10/10/2009 5:46 pm
 mboy
iirc, the original Hope BULB's with the spider for the disc rotors, and the newer ones with 6 bolt IS disc fitment, have different sized flanges, so require subtly different spoke lengths... Sadly...
Posted : 10/10/2009 6:10 pm
