Bit of a stupid question, how do i change the sag on this fork? I have read that the only way you can do it is by changing the spring. I have the standard spring in it at the moment so am guessing i need a firm spring unless i can adjust it as is.
Sorry for a bit of a stupid question, have managed to set all my previous forks but this is my first u-turn and instructions are not very clear
Thanks
You'll need the appropriate spring for your weight aye. Easy job to change though.
Ok, thanks for that. guess i will have to seek a firm/xfirm spring then.
Can't remember what spring in mine - pretty sure it's a Firm, and I'm around 14st loaded up, if that's any help. Did try a Medium but it was TOO squishy.
mine is too squishy (love the technical term) too, need something more.
Oh I'm ALL about the technical terms. There are tons of guides online on how to change the spring, but if I can do it anyone can. Worth sticking a post in the wanteds in here too, people often have springs kicking around.
pre-empted on the wanted, already done ๐
Oh aye! Good luck ๐
thanx ๐
