ok im a bit stumped, my new rear crossmax st wheel has a bit of play, to the point when you get off and rock the wheel side to side you can hear a pretty awful noise (like a creak/crack noise)
ive tightened the rear one up and instantly that noise went when rocking side to side, the question is how tight do you do it up??
also the front is the same, but i cannot for the life of me figure out how to do the front one? ive taken the 15mm caps off and still couldnt see where you put the bearing adjustment tool in?
cant see any instructions anywhere on mavic either
I've never had to tighten the front, only the rear. I'm not sure that you can. The answer to "how tight" is; not very. It's only for preload, and over tightening will reduce the bearing life (I learnt this the hard way).
It's the drive side on mine, IIRC
Edit - no, just had a look, must have imagined that.
right so the front one cannot be adjusted then? that would make sense given i cant see how its possible with the tool
the back one i did pretty much as tight as i could with the tool (without snapping the little plastic bits off) shall i then back off a bit then?
Check page 15, looks like there isn't one.
Suspect there's a new bearing in your future.
Mavic and their crayzee adjustable sealed cartridge bearing hubs? ๐
You need to "do it up" until the point where there's no play but it still spins freely, if there's play in the bearings themselves you should still replace them.
to be fair the shop did say they will need tweaking up after a few rides and after they have settled in, it wasnt major side to side play but there was a bit, ive tightened it back up and wheel seems to be spinning freely, at worst ill back it off a touch
so HG on the front is it suggesting there is no front adjustment to be made (cant acccess pdf doc at the min)? to be honest it could be that i didnt do my maxle up tight enough as silly as it sounds
Keep checking them periodically. They do need nipping up from time to time.
hmmm just spoke to shop the front ones are done with the tool to, said its not as obvious as the rear one (where the tool just fits in the holes), but said that its on the non disc side where you tighten up the front bearings
im not arsed about staying on top of it, the wheels are amazing, its a really easy job to sort the rear out, just need to do the front now
