Adding pop lock to ...
[Closed] Adding pop lock to Rockshox Sid
Gor a pop lock set up on my Recon forks, but updgrading to Sids. How easy / difficult is it to transfer it over? any 'how to' guides available ?
Posted : 09/03/2009 4:01 pm
 rob2
Hi, if it is like the old ones its a piece of p***.
Just undo the cable on the Revs (held in by a 1mm (I think) allen key bolt), remove the revs from your frame, squirt your new forks into the frame and then re-attach the cable making sure the cable is tight when you tie down the allen key bolt. Bob's your uncle and its done.
Posted : 09/03/2009 4:28 pm
