Basically just want to check the pressure and maybe add some air to my forks, am I right in thinking this is possible with the aforementioned forks and if so how??
Ta,
Phil
Posted : 09/03/2013 6:04 pm
unscrew cap on top of fork leg. screw on shock pump and check. bobs your uncle and fanny's your aunt !!!
Posted : 09/03/2013 7:20 pm
unless you have the coil version
Posted : 09/03/2013 7:30 pm
Well it's got lock out on right leg and preload on left??
How would I know if its a coil?
Posted : 09/03/2013 7:34 pm
If its got a preload knob then its a coil spring fork not air.
Turning the preload knob towards + will make them a bit stiffer initially.
Posted : 09/03/2013 7:38 pm
And the award for biggest div on Stw goes too...........Me ๐
Posted : 09/03/2013 8:00 pm
