Adaptors for post m...
[Closed] Adaptors for post mount fork and IS caliper - HELP!
 Aus
Got a set of Rock Shox SIDs, post mount and a Hope Mono Mini IS caliper. Is there an adaptor that I can use that'll avoid having to up-size my rotor from 160 to 183?
A2Z seem to suggest they might have one, but it's not clear? Will a Shimano one only allow a 180mm rotor?
P.S And if I have to upgrade my rotor, are floating rotors worth the extra???
Posted : 06/04/2010 7:08 pm
 Aus
does this one allow me to keep my 160mm rotor?
http://cgi.ebay.co.uk/A2Z-Mountain-Bike-Disc-Brake-Adaptor-AD-ISPM160-BLACK-/300404331989#ht_1758wt_958
ta
Posted : 06/04/2010 7:12 pm
yes it will work i have the same one
Posted : 06/04/2010 7:21 pm
no not possible new rotor required.post pount 74mm to 51mm caliper is will have to be run with a 180+ rotor.
Posted : 06/04/2010 8:41 pm
Posted : 07/04/2010 9:34 am
Says this on the ebay advert..
How it Works:
If you're original rotor diameter is 160/165mm by adding the A2Z ISPM-160 adaptor to your fork will allow you to run your rotor at the current size 160/165mm so you do not have to Buy a new Caliper/Caliper Half.
I bought a Hope one recently for the same problem, with that one I had to up the rotor, but I was doing that anyhow, the probelm I have is there isno direct path to the upper Post mount bolt, making setup tricky..
Posted : 08/04/2010 3:23 pm
ive got an a2z on my 180 is caliper and it works with my 180 rotor on my pm forks . maybe im just lucky ๐Ÿ˜‰
Posted : 08/04/2010 3:25 pm
