Aching feet after r...
[Closed] Aching feet after riding......comfy shoes?
 ton
[#6253751]
i wear flat shoes for riding (teva links or scarpa approach shoes), and my feet are fine whilst riding, but after riding they hurt like heck.
they hurt under my arch and on the top, on the big flat area above my toes.
i was thing about try spd shoes again, but foot pain was the reason i stopped using them in the 1st place.
or ideas for some really comfy shoes for after riding....some that kinda massage your feet... 😀
Posted : 07/06/2014 9:11 pm
Different insoles and don't do them up as tight may actually be the answer!
Posted : 07/06/2014 9:26 pm
Ie insoles with arch supports in I bet your existing shoes are letting your arch collapse......had it with a pair of Sidi shoes until I put some speshalised from an old pair of carbon race shoes, shoe insoles in
Posted : 07/06/2014 9:28 pm
I would have guessed it was lack of a stiff sole?
Posted : 08/06/2014 12:17 am
Stiffer shoes and arch supports (if your arches drop), well fitted shoes and pedals big enough to stand on without overhanging. Proper stiff SPD's with floaty pedals (Crank Brothers for me) are the other option (with the arch drop corrected if needed).
Posted : 08/06/2014 12:19 am
I always had this before I started getting shoes with a stiffer sole.
Posted : 08/06/2014 12:21 am
get some proper shoes for flats and you shouldn't have any issues..as said stiffer soles..i've had this if I commute in normal trainers on the bmx. Too much pressure on the arch of the foot. Solved by wearing good quality skate shoes with a stiff sole.As the sole is flexing, i guess the extra pressure and flex on the sole above the pedal is causing pressure on foot from the upper part of the shoe being stretched..which may be causing a pressure point..restricting blood flow ?? maybe
think you can also get mouldable inner soles for ski/snowboarding.. either for your riding or post riding shoes ..or both
Posted : 08/06/2014 1:56 am
 ton
shoes are teva links, which are designed for riding
pedals are v12's
Posted : 08/06/2014 10:04 am
Try stretching your calves etc.
This might be the things thats hurting
The plantar fascia
http://www.nhs.uk/conditions/heel-pain/pages/introduction.aspx
Posted : 08/06/2014 10:26 am
+1
I had some issues recently where my heel was sore enough that I started walking funny, which then gave me hip pain. Calf stretches, (face upstairs with ball of foot on edge of step. Drop heel and hold, one leg at a time), sorted me out quite quickly.
Posted : 08/06/2014 10:42 am
I use sole custom footbeds in my bike and running shoes. Really helped with foot pain.
Posted : 08/06/2014 1:39 pm
