A little 2x10 knowl...
[Closed] A little 2x10 knowledge, please.
I have a Cotic Hemlock which is a bit of a bugger for chainsuck on my triple chainset. Rings and chain are new, but unless my gear change is squeaky clean, it snags up.
A double chainset is going to give me a bit more clearance due to chainline, I suspect, but will it be enough to make a difference? Is the extra clearance offset by the fact the inner ring is bigger? Does the bigger inner ring help avoid chainsuck?
Cheers for any input.
Posted : 17/09/2014 11:48 am
Any assistance from the evening crowd? The 2x10 chainset is on the way anyway....
Posted : 17/09/2014 7:05 pm
I was able to space my 2x chainset out to improve the chainline. Can't comment on the chain suck as I didn't suffer from it...
Posted : 17/09/2014 7:12 pm
I think on my double SLX cranks the inner is 24T which only 2 more than the granny on the triple I took off so I can't imagine it would make a huge difference. That said I never had chain suck with either of them so none of what I've said actually helps.
HTH ๐Ÿ˜€
