looking at reba forks what is the difference between RL & RLT & RLT TI
Also I have a Turner Flux with Shimano MT65 wheels can I have a straight threw axle? if so what size? 15 or 20mm
is there a fork with 120mm that winds down to 100mm?
cheers
Craig.
anyone???
RLT Ti is the one to go for (2011) 2012 will be different with DNA damping, and I'll go for a 15mm maxle as a little lighter for the shorter travel forks.
has to be 120mm
so would 15mm maxle fit or would I need QR?
RL = tooled flood gate
RLT = externally adjustable floodgate.
RLT Ti = Black box MoCo
As per Loco I'd suggest the 2011 120mm RTL Ti or 2010 120mm Team's (same thing as the RLT Ti & still some about), and come with the proper 20mm axle not that stupid 15mm thing.
CAN i BE HONEST AND SAY WHAT THE F@#K are maxles, axles?
Maxles are the thru axles, which come in 15 or 20mm, just a brand name/system, like the Fox/Shimano 15mm
Maxles are the bolt through 12mm axle on the back of a bike. Makes it nice and stiff apparently.
As a Fox user I'm only pretty sure that Maxle is on the fork too, them and Maxle light. Both 20mm.
and the back too as above, but didn't want to complicate things any further 😀
do they only fit threw certain hubs or am I ok with my shimano mt65's?
if they are QR shimano hubs then you are stuffed and have to go QR. Or use it as an excuse for a new wheel 😀
they have qr on at the mo!
I only wanted to be spending around £350 too
You'll just have to stick with QR forks then.
Craig, in a few of your previous post you have SID's fitted, it "may" be possible to extend these to 120mm.
Post the year and exact model and someone maybe able to confirm this...
You get your extra 20mm with minimal outlay...
how about these: http://www.merlincycles.co.uk/Bike+Shop/Frame++Forks/Forks++Shocks/Rockshox+Suspension+Forks/2011+Sid+XX+-+QR+Axle+-+Remote+Lockout_RS-SID-XX.htm
make sure you sign in for VIP prices.
apart from a little weight is there any difference between the sids now?
well they'e introduced a 80/100mm or 100/120mm version this year, so I imagine the previous version's were all 80/100/120 but have never paid huge attention to em personally.
think I'm going to go for the 2011 reba team. its in silver but I can just about deal with that!
the equivalent reba rlt ti is loads more expensive and apparently exactly the same as the 2010 team
