A couple of recomme...
[Closed] A couple of recommendations required...
Gear cables - continuous outer to be fitted to Orange 5, what do you suggest?
Long finger gloves - need to replace the 661 Raji's that have fell to pieces, non padded, hard wearing, cool (both temp and looks)?
Hope ceramic BB bearings - is it best to send them back to Hope to have new bearings fitted? Have done the maintenance that Hope suggest and after 2.5 years there is a bit of play in them so need replacing.
cheers
Posted : 12/04/2010 6:26 am
For continuous outers i just go down to my lbs and get em to cut the lengths i want from their stock outer but then there's probably a nice shiny goodridge recommendation about to be made...
I gave up on Rajs after my fingers went through the tips of two pairs. I now use Thor Phase gloves in everything but sub zero temps - they give pretty much the best balance between all things. Light padding mind so they might not be what you want.
Posted : 12/04/2010 6:39 am
I've given up on all other gloves. Thor Phase are where it's at, they are lightly padded but I don't find them a problem in summer here (25-30degC most days). They are the only gloves that have lasted more than a couple of months without ripping. The sizing is great too.
I run full length outers and just put on anything that's cheap, I've never noticed any difference.
Know nothing about ceramic BB's!
Posted : 12/04/2010 6:43 am
A roll of Shimano SP41 should keep you going for a while
Posted : 12/04/2010 6:47 am
How do the Thor Phase size up against the raji's?
Posted : 12/04/2010 8:42 am
I must admit I can't remember! I must have found a sizing chart somewhere (maybe Thor's own site) and the ones I thought would fit me did fit me. If that makes any sense?
Posted : 12/04/2010 9:19 am
