Which is stiffer on a conventional 9mm dropout fork (26"/130-150mm)?
slainte โ rob
mmm.... I don't know the answer to that; my best guess would be the RWS is stiffer because it's tighter, but I'm no engineer.
However, bear in mind that a *working* RWS skewer may be stiffer, but they have a tendency to drop out of that state of workingness...
The Superstar Components version works very well on the two bikes I have with 9mm fronts.
Already have an RWS skewer (still working) on the front but have just switched to Flow/Superstar Switch wheels and was just wondering whether to take a punt on some 9mm axle adaptors and a QR from Superstar.
slainte โก rob
As mk1fan says, the Superstar version works really well IME.
superstar is fine (or fireeye from CRC, same). despite the plastic bush bit.
Bump for a few more opinions from the evening crew and those half-cut from celebrating the TDF victories.
slainte ๐ rob
Why not get the 10mm rear one too.
Already got 10mm on the rear.
And for only 18 quid for adaptors and QR axle, I've just taken a punt on the front now too.
slainte ๐ rob
RWS - better torque than a QR.
