Hi STW,
I need a need rear wheel, but can't find one the right size with a 9mm quick release axle.
Is this due to Covid supply issues, or aren't they being manufactured anymore?
I could buy a 12mm and adaptor, but would prefer not to if it can be helped.
If its a standard qr rear, isn't it a 10mm axle, I think 9mnis the front. Most were then 5mm qr axles through them or some had a 10mm DTS thru axle into normal dropouts.
Not sure what size wheel you are looking for to have tried to help find one
What they said
9mm is for the front.
Thanks, it sounds like I need to do some measuring and head to a bike shop.
Cheers guys
Rear QR 10mm: https://www.superstarcomponents.com/en/10mm-rear-qr-through-axle.htm
Front QR 9mm: https://www.superstarcomponents.com/en/9mm-front-qr-through-axle.htm
Stock is available as I can see.
Have them both on my do-it-all Plug3. Abusing it a lot, no complaints...
Cheers!
I.
You haven’t said what rim you want but I bought a pair of Mavic xa 29 wheels recently. They come standard with 100x15 front and 142x12 rear axles but adapters for qr included. £240 a pair in stock at CRC currently
