9 speed rear Casset...
[Closed] 9 speed rear Cassette & Chain
9 Users
It's time to replace my chain and cassette and wondered if anyone had any opinions about which manufacturer is best (as if I needed to ask...)
I currently have a shimano chain and cassette running through a Sram xo long cage rear mech. It all works fine. Any reason to change to a Sram chain?
Posted : 06/04/2010 10:01 am
i always buy sram chains, for the magic link
but i buy shimano cassettes usually as XT is cheaper than PG990(?) - i was less picky when i had a proper freehub.
Posted : 06/04/2010 10:05 am
A new chain won't run on a worn front chain ring, you usually have to replace at least middle and small rings at the same time as replacing your chain & cassette to avoid chronic chain suck. PG990 cassette and PC991 chain from CRC comes to about 80 quid - top quality kit at a very decent price. Worth getting XT grade or Middleburn front chain rings as they last much longer than lesser ones
Posted : 06/04/2010 10:10 am
I like SRAM chains & cassettes - CRC had PG990s for £45
I usually go through 3 chains for every cassette & 2 cassettes for every set of chain rings
Posted : 06/04/2010 10:12 am
IME shimano chains shift slightly better than SRAM, though the latter's joining links are nice.
IME expensive cassettes do not last any longer.
Posted : 06/04/2010 10:14 am
Marchisio sprockets seem to last longer than most.
Highpath
Webbline
ParkerInternational
Although they do not have the same slick gear changes as Sram, Shimano.
Posted : 06/04/2010 10:40 am
Ive just replaced mine, thought I would try SRAM for a change, I usually use XT. Seemed that the 980 SRAM cassette was more or less equivalent on price so got that. Its not as good as an XT though and has less (only 5?) of the cogs held by the ally spider. Will go back to XT or look for a 990 next time. Check out Merlin for good deals on chain + cassette
Posted : 06/04/2010 10:48 am
XT or SLX cassette, KMC chains for me.
robarnold wrote, "A new chain won't run on a worn front chain ring, you usually have to replace at least middle and small rings at the same time as replacing your chain & cassette to avoid chronic chain suck."
Or, replace your chain on time.
Posted : 06/04/2010 7:04 pm
[i]IME expensive cassettes do not last any longer. [/i]
True enough, generally though, it's an easy way of loosing a bunch of weight. LX 9 speed 11-32 327g, XT equivalent 260g.
FWIW XT cassettes, SRAM PG951 and XT mech seems to work for me...
Posted : 06/04/2010 7:23 pm
