9 Speed Medium Cage...
[Closed] 9 Speed Medium Cage (GS) Rear Mech for 36T cassette?
Looking to fit a 9 speed 11-36T cassette as part of a 1x9 set up. Are there any medium cage (GS) rear mechs that work with the 36T cog? Or do i need to fit a standard long cage mech?
(Im keen to keep a medium cage mech if i can as ive used it with a 1x9 11/34 set up until now and its helped to keep the chain nice and tight)
Posted : 23/12/2011 5:12 pm
I think it'll take it, but are you sure it's a 11-36 and not a 12-36
Posted : 23/12/2011 7:53 pm
As Steve says 11-34 or 12-36 are your choices with 9 speed unless you are modifying something . I would expect a medium cage should be fine . Put the casette on and try it , worst that can happen is that you'll have to buy a new long cage mech .
Posted : 23/12/2011 8:04 pm
I used a medium cage X9 with my modded 11-36... Shifting wasn't brilliant into the biggest ring, but it was acceptable- always felt a bit like it does at the end of a muddy ride when everything's a wee bit sticky, but didn't really get any worse.
Posted : 23/12/2011 8:07 pm
hmmmim having issues with a 36t casette with 36t chainring on a medium cage rr mech, not sure what the exact problem is though, chain length is a bugger to get right
Shimano reckon all their MTB mechs will work with a 36T sprocket.
Cage length is only to wrap all the excess chain, so is total range dependent.
Typically 45T for long cage and 33T for medium cage.
Short cage (Saint is the only MTB mech) is for single chainring only and should be OK for 12-36 cassette with the mode adapter in the correct way.
PaulD
Posted : 23/12/2011 9:59 pm
PaulD - Member
They do now. Until they released the 36T 9-speed sprocket they said none of them would, and you had to buy 10-speed if you wanted that sort of nonsense, and this was one of the reasons they were changing format ๐Ÿ˜†
Posted : 23/12/2011 10:01 pm
Shimano try to play it safe.
Their road mechs will handle a 30T easily and some claim a 32T yet Shimano will only state a 27T limit.
I always back off the load when shifting to a larger sprocket or ring, from my youth with downtube non-indexed levers, so a slightly poor change nowadays would probably go un-noticed by me.
PaulD
Posted : 23/12/2011 10:08 pm
