I need an 83mm bottom bracket for one of my bikes, but the choice seems a bit limited. What's the difference with a 73mm one, is it just the length of the tube between the cups?
If so does anyone know if a Race Face plastic tube bit will fit a Hope bottom bracket?
Posted : 15/11/2011 10:10 pm
68/73mm cranks are usually interchangeable with the use of a few spacers 83 mm ones are usually seperate cranks, i assume the only difference is the plastic sleeve on the bb
you can but hope ones here
http://www.ukbikestore.co.uk/product/231/bbsp101/hope-bottom-bracket-centre-tube.html
this may help,
http://www.sheldonbrown.com/gloss_bo-z.html
Posted : 15/11/2011 10:20 pm
ah, well found. That should do the trick!
Posted : 15/11/2011 10:24 pm
