700c wheels on Kona...
[Closed] 700c wheels on Kona Lavadome Frame
[#4350851]
Hi,
I have a 21" kona lavadome frame with sliding dropouts, and want a hybrid bike. Is it possible to use 700c wheels on the frame with the correct forks? I have tried putting some 700c wheels on and they fit, but will the geometry be messed up with 700c compatible forks?
Posted : 11/09/2012 12:49 pm
You can use non 700c forks if you want to keep the geometry.
Posted : 11/09/2012 1:02 pm
But then i guess I cant use a 700c wheel on the front? umm, will see.
Posted : 11/09/2012 1:57 pm
it'll be fine with the mtb forks - the issue is the brakes. No problem with discs but if you run Vs then it's more fiddley.
If you fit 700c forks they are usually shorter C2A than MTB forks so it'll speed up the steering a bit, and drop your BB.
Posted : 11/09/2012 2:03 pm
I would use a 420 or 440mm rigid MTB fork in the frame. If you put a road fork in it will drop the front end by a good inch or two making it too low IMO (depending on make).
I use 440mm forks on mine...
Posted : 11/09/2012 2:04 pm
My 1999 Caldera ......
420mm front forks as it was originally designed for a 65mm fork 😉
35mm tyres pictured with plenty of room.
Posted : 11/09/2012 2:11 pm
Errmmm pulls up a chair
I have my '93 converted to drops, and am also toying with idea of bigger wheels. Trouble is I don't have disc mounts
So.......
1. Is there a fork available that Llows you to use 700c wheel and v brakes?
2. Assuming 700 c wheel will go in the back, is there a way of getting the v brake to fit?
Thanks
Posted : 11/09/2012 2:19 pm
@ Charliemort .... The neatest way I have seen this done is by using Pauls Monolites
That way you can re use the std frame and fork mounts.
A cheaper option is to use a Mavic 700c adapters. Cheaper but IMHO not as neat:
Posted : 11/09/2012 2:35 pm
Just noticed this post - but i did exactly this with my lavadome - thread linky below
29er halo wheels and white bros carbon 26" forks
At the time i had 700x28 tyres fitted but have recently put on 700x40's just for a change - no issues at all.
Rides really well
http://singletrackworld.com/forum/topic/new-bike-build-pics-1
Posted : 01/11/2012 2:10 am
