7 speed shifter wit...
[Closed] 7 speed shifter with 6 speed cassette?
I've recently gotten hold of an old tandem, on which I am intending to tour the Tour of Pembrokeshire. I was hoping to upgrade a few bits using some spares. The shifters are very old and hard to operate so I wanted to swap them with rapid fire shifters. However, I'm not sure if my 7 speed shifters would work with a 6 speed cassette if I adjusted the limit screw to only allow the shifters to work over 6 cogs. Can that work or is the spacing of the cogs an issue?
Posted : 13/04/2017 10:54 am
Spacing is an issue, will not work. 7s cassettes are cheap though.
Posted : 13/04/2017 11:01 am
Thank you
Posted : 13/04/2017 11:09 am
Not sure they made 6 speed cassettes. It's probably a screw on.
I don't know if you can swap a 6 speed for 7 speed screw on so you'll prob need a new hub or wheel.
Posted : 13/04/2017 11:18 am
 Jerm
http://www.sheldonbrown.com/cribsheet-spacing.html
This may help you
Posted : 13/04/2017 12:39 pm
I've done exactly this on 2 bikes. Shimano 7sp shifters with old 6 speed rear screw on freewheel (Not the newer cassette freehub style). No problem at all. Just adjusted the limit screws as u said.
Posted : 13/04/2017 12:45 pm
