68mm bb, what space...
[Closed] 68mm bb, what spacers and which side for HT II?
Swapping bits over for a mate.
Frame at the mo has what it looks like is 2x2.5mm drive side and 2.5 non drive but when I put the spindle through there's not enough of the spline to put the crank on.
Or have I not pushed it through enough?
XTR chainset so not 'given it loads' yet with the rubber mallet!
Thanks
Posted : 05/11/2014 12:29 pm
 jimw
You have the right spacer placings, so may need a gentle push to seat
Posted : 05/11/2014 12:34 pm
Cheers.
I've tried a gentle push, just wondered how much effort with the rubber mallet is needed, spindle is greased too.
Posted : 05/11/2014 12:38 pm
More persuasion required.
Posted : 05/11/2014 12:50 pm
Any preferred technique, or just batter it?
Posted : 05/11/2014 12:57 pm
 jimw
Which xtr chainset is it?
Edit:
Not the best quality but thinking about how much to hammer reminded me of this
Posted : 05/11/2014 1:01 pm
M960 & an XT bottom bracket.
Posted : 05/11/2014 1:09 pm
 jimw
I have one of those and it can be tight on new bb. I use a soft piece of pine on the narrow steel rim of the shaft that protrudes slightly from the inset crank arm and tap gently-if that makes sense!
Posted : 05/11/2014 1:11 pm
Great I'll try that cheers.
Posted : 05/11/2014 1:18 pm
I just **** it with a rubber mallet.
Posted : 05/11/2014 1:50 pm
 jimw
Yeh, TBH so do I on unpainted XT etc. but the M960's have a coloured lacquer coat that I am much too much of a tart to want to damage
Posted : 05/11/2014 1:55 pm
 igm
Just have a re-measure of that bottom bracket shell too.
Just in case it's grown overnight.
Posted : 05/11/2014 1:58 pm
M960s are just anodised, like all other Shimano cranks. It's just a shiny anodising, and it wears just as fast with heel rub.
Posted : 05/11/2014 1:59 pm
Jims tip worked cheers.
Just got to work out the arse about face reverse gears whatever they're called, where the cable is slack in 1st.
Posted : 05/11/2014 6:57 pm
Low normal/rapid rise.
Aka 'wrong'
Posted : 05/11/2014 9:40 pm
 jimw
I quite liked RapidRise with combined XTR M 960 brake/shifters ( I know, often voted most useless 'innovation' in mountain biking but I found it quite intuitive), but when I decided to upgrade the brakes and used the RR rear mech with conventional shifter I couldn't get my head round it so changed the rear mech. Unfortunately I had just replaced it as the old one had been damaged.
So njee is right in my opinion about it being wrong if with conventional shifter.
Anyone want a hardly used XTR M970 RR rear mech?
Posted : 06/11/2014 12:00 am
Well I got there in the end, mate seems happy with it.
Cheers for advice all.
Posted : 06/11/2014 9:47 pm
