650b plus in a non ...
[Closed] 650b plus in a non boost 29er fork?
Does this ever work out ok?
Posted : 06/01/2017 11:16 am
For a very narrow definition of B+ it might.
Posted : 06/01/2017 11:30 am
2.8NN's on 45mm rims cleared through a standard revelation with about 4-5mm each side.
but add in a bit of mud and some wheel flex and they rubbed quite a bit.
gone back to 29.
Posted : 06/01/2017 11:34 am
3 inch nobby nic on 35mm rims in my 36s worked decently. It didn't have huge mud clearance but it wasn't so different to what you get with some standard fork/tyre combos. It'd not be your choice if you were building a full time plus bike but I was happy enough.
OTOH, for me the sticky muddy conditions where the clearance would be an issue, are conditions where I'd want to be on a 29er anyway, not on plus. YMMV there. I never got to try it in snow, that could have been a dealbreaker
Posted : 06/01/2017 11:50 am
I've got 3" Bridgers in a 2014 Fox 34 29er. Clearance is a little close at the lower seal bulges but it doesn't rub. They're on 30mm internal rims.
I hear that the more recent non-boost fox 36's have a lot of clearance in 27.5 and 29 flavour.
Posted : 06/01/2017 12:38 pm
3 inch Purgatorys on 30mm rims, in a 29" Pike here. Lots of clearance above the tyres, not too much either side but I don't really ride in thick mud so it's not really a problem for me...
Posted : 06/01/2017 12:43 pm
[url= https://c1.staticflickr.com/9/8693/27953015120_1b73ae1812_z.jp g" target="_blank">https://c1.staticflickr.com/9/8693/27953015120_1b73ae1812_z.jp g"/> [/img][/url][url= https://flic.kr/p/JA7vwy ]Tyre rub[/url] by [url= https://www.flickr.com/photos/77564901@N06/ ]Metalheart-UK[/url], on Flickr
After only ~10 hours use in the dusty dry (mostly)
Posted : 06/01/2017 1:27 pm
My Dt Swiss single shot XMM have enough room for a 27.5 FBN 3.25 on a dually rim with loads of room. I've actually ridden them with a 29er 3.0 dirt wizard on a rabbit hole, no rubbing, but a bit close for comfort.
Posted : 06/01/2017 2:14 pm
Ran a 3" WTB bridger in a 29er DT OPM fork for 'project High Fatitude' no problem, bags of room, no buzz whatsoever.
Posted : 06/01/2017 3:05 pm
I'm running a 2.8 Rekon on a 30mm internal rim in a standard Pike. No clearance issues, I've even got room for a mudhugger in there. Tried a 3.0 Vittoria Bomboloni but that was a bit tight.
Posted : 06/01/2017 6:22 pm
