650b inner tubes
[Closed] 650b inner tubes
Hopefully (fingers crossed) my new Five arrives this weekend!
Now where do people get there 27.5 inner tubes from? I am assuming that you need different size ones from 26?
Can't find any at Merlin or Wiggle.
Posted : 12/12/2013 9:20 pm
Ive never tried it, but having seen how far a 26in tube will stretch, I'd imagine a 27.5in tube is almost unnecessary. 26in should fit just fine.... ๐Ÿ™‚
Although I imagine I'm wrong in the usual STW tradition. ๐Ÿ˜‰
Posted : 12/12/2013 9:22 pm
I use std 26", just pump em up a bit before fitting..
Scwalbe say their 29er tubes are for 650b as well. But I've also used 26 inch with no problems.
Posted : 12/12/2013 9:29 pm
Giant and Nutrak do them. Both get good reviews.
Posted : 12/12/2013 9:31 pm
Good to know I can use the old ones if I get caught out.
Will have a look for some of those giant ones, know where you can get them?
Posted : 12/12/2013 9:59 pm
You can get some maxxis ones from CRC
Posted : 12/12/2013 10:01 pm
Schwalbe do them and make good tubes http://www.bike-discount.de/shop/k2023/schlaeuche.html
Continental tubes are also good and their 29 tube is branded 28" so that would work http://www.wiggle.co.uk/continental-quality-mtb-inner-tube/
I'd still use up my 26 tubes first as they'll still fit and they'll last for ages as it's pretty rare to get a tubeless failure.
Posted : 12/12/2013 10:20 pm
1) Why are you not using tubeless? Get some electrical tape, seal the rims, cut a (threaded, with a locknut) valve from your old redundant tubes, fit it, pump it up, if it doesnt go up, add more tape (a whole roll weighs 30g, still only 20% of a tube, go nuts!), remove one side, add stans, pump up, forget about it for 6 months.
2) 26" will fit, I've put them in my 29er before, as above, just pump them up a bit before fitting.
Posted : 13/12/2013 8:52 am
Tinas - for emergency spares?
Yes 26 should fit, also can get Maxxis from CRC.
Posted : 13/12/2013 8:55 am
my new 650b bike came with 26 tubes
fortunately the rims also came taped for tubeless so its no longer an issue!
Posted : 13/12/2013 8:57 am
You know me, I break my arm more often than I get punctures, that's actualy true, I've had 3 punctures in the last 2 years, two on the same ride ona new bike that still had tubes fitted!
Posted : 13/12/2013 9:00 am
You could try these guys:
http://www.innertubeshop.com/products/27-5-650b-mtb-wide-inner-tube-presta
Posted : 10/12/2014 5:18 pm
