650b - a fair obser...
[Closed] 650b - a fair observation
60 Users
theocb - Member
Why doesn't that make sense?
Because you don't compare 26 inch wheels and fat tyres with 650b wheels and thin tyres- you compare like with like. And the reasons for fitting a big tyre are not the same as the reasons for fitting a bigger wheel. The 2 are not the same at all.
Posted : 08/01/2014 12:31 pm
 chip
I, a size 10 shoe, because I choose to wear chunky boots and trainers now know what it is to be a size 12 and feel the pavement come alive as my huge clown boots bridge the uneven terrain below. 😀
I could probably fit bigger wheels on the 26 ragly frame I recently bought but would not want to as the bottom bracket would be too high for me. That is a part of geometry that I really do notice a change in when riding. Just a small increase in what I am used to and I feel really high up and less balanced.
Posted : 08/01/2014 12:38 pm
[quote=theocb ]Most riders have tried it and are happy with that as a wheel size.
So what you're saying here is that because people are happy with what they have that they would be more happy with something new which approximates what they already have and that that justifies introducing a new standard which makes stuff incompatible? Or have I totally misunderstood your argument?
A low volume tyre is not a skinny tyre!
Most have moved to higher volume balloon tyres as the norm so the rim standard has now slightly changed to take note of that allowing 27.5 to be the new standard giving wider options.
Less tyre roll and less suspension travel= win imo.
ahwhiles. Tyres have changed man keep up. Even a XC conti 2.25 comes up a smidge under 27.5.
A 2.7 Diesel might have weighed a little bit more than my 600 gram xc Tyre BUT it still might have measured up smaller in circumference.
(note. 26ers use 22inch rims and 650b use 23inch rims.)
Northwind. That makes no sense. Tell me the reason why people fit high volume tyres and the difference between a slightly bigger rim (not a wider tyre.)
Chip. You don't seem to understand Geo.
Posted : 08/01/2014 12:40 pm
[quote=theocb ]Most have moved to higher volume balloon tyres as the norm so the rim standard has now slightly changed to take note of that
Ah, so that's the reason for the change. Because you need a bigger rim to work with a fatter tyre. It al makes sense now 🙄
Posted : 08/01/2014 12:42 pm
I got that as bigger tyres makes a higher BB??
I have no idea what most of the other stuff your on about,
A fat tyre on a 26" will not ride the same as a skinny tyre on a 650b
Posted : 08/01/2014 12:54 pm
 chip
I understand that a 26" bike with 650b wheels will not be the same as a 650b bike as the geometry has been adapted to allow for the bigger wheels.
Which some people must not as they either wish to fit bigger wheels to there current bike to join the 650b train.
Or tell me that my concerns are unfounded as I could simply in future fit a 27.5 fork to my bike if 26" forks became unavailable.
I suggest these people do not understand geometry.
Also one of my bikes has a higher bb and I understand that I genuinely feel more aloft and less at one with my bike than I do on my other bikes .
I am not saying this has anything to do with wheelsize apart from would be the case if I just fitted bigger wheels to my current frames .
theocb - Member
Why do people fit high volume tyres? For the high volume, obviously. What are you trying to ask?
What is the difference between a bigger rim? Assuming the rolling circumference is the same, the tyre has to be smaller. Again, obviously, so again what are you actually trying to say here?
Not trying to be funny but you seem hugely confused, earlier you were claiming that most people had tried 650b, now you seem to be saying that a a big tyre on a 26 inch wheel is the same as a small tyre on a bigger rim but at the same time pointing out differences... You can't have it all these different ways.
Posted : 08/01/2014 12:55 pm
...but please keep it up because it's all very entertaining whilst I sit here with my tea and biscuits. I'm hoping theocb is conjuring up a fantastic sleight of word that will have me even more bamboozled.
Posted : 08/01/2014 1:07 pm
 edd
This!
I run 26" bikes with 2.35" to 2.5" Maxxis tyres. On a 650b bike I would also choose to run 2.35" to 2.5" Maxxis tyres. There's no reason why a rider would change tyre width because they've changed wheel diameter.
Posted : 08/01/2014 1:10 pm
This thread reminds me of the NSMB vid 'How to be a Mountain biker'
'Choose a favourite wheel size. Be a dick about it.'
Posted : 08/01/2014 1:15 pm
 chip
I think (does not mean I am right) people use balloon tyres ( your words ) because they work better at lower pressures, which is desired to soak up the bumps and thumps, a first line of defence for you suspension.
Which you would still benefit from with bigger wheels.
Posted : 08/01/2014 1:19 pm
in response to something I said about most people already having tried 650b (within a few mm's) by using high volume high profile tyres on 22inch rims.
I just wanted you to explain what you meant (we are not talking about wider or skinnier tyres.)
I'm saying you can get the same level of grip from a lower profile similar (maybe slightly slimmer) width tyre on a 23 inch rim but the advantage would be less sidewall flex and better rolling resistance
If my wheels measure 27.3 inches then I am getting a very clear indicator of what my 27.5 wheels ride like. (hardly going to effect geo is it? they both measure the same near as dammit)
This comparing like for like is also a red herring. Are you implying if I have some 23inch rims the law says I must use inefficient tyres because that's what I had on my 22inch rims
If I can get a tyre to give me the same benefits as a high profile high volume tyre without the disadvantages then why do you think I need to measure like for like. I want wheels that tick the right boxes and work for me I am not so set in my ways I have to use the same branded tyre with the same volume regardless of rim size. You don't jump on a 29er and stick a minion up front. The grip in corners on a 29er is immense so you don't need that big tyre for the same level of grip meaning a choice of a faster rolling tyre with the same grip (it's a new standard and allows new options for the same benefits with other disadvantages.)
A 23 inch rim offers advantages and disadvantages. Weigh them up and make your choice.
We have slipped away from the OP. I thought the Blog report link was fine apart from the idea that nobody has tried 27.5 wheels before they went and bought them. I think most riders have tried 27.5 and are more than happy with that as a wheel size hence all the big old tyres sold on trail bikes. The bike has evolved and new standards have been born.
People now seem transfixed on the size of tyre rather than the performance of it 😕
Different opinions and all that.
Posted : 08/01/2014 3:48 pm
Rolling resistance would be higher generally as pressures would have to be higher; and sidewall flex is better reduced with wider rims. I'd take a big tyre and wide rim 26" over a skinnier 650 set up every time, but a wider rim / tyre on 650 is better still ime/imo/personally speaking etc.
Yes and this post didn't help. Sorry, I can't resist sometimes )
Posted : 08/01/2014 3:59 pm
Don't feel bad. 😀
Posted : 08/01/2014 4:08 pm
so what you actually meant was
"due to the general trend to fit bigger tyres to existing 26in wheels most people have ridden bikes that have wheels of an outside diameter close to the mythical 27.5in number that is now being mis-touted as the next big thing"
when what you actually said was
"most people have tried 650B"
I know what you're getting at but the two statements are not commutable.
Posted : 08/01/2014 4:14 pm
I dont think he's talking about commuting 😉
Posted : 08/01/2014 4:18 pm
Back when 650b was announced I came to the conclusion it was the most shameless, money grabbing, nasty, thoughtless, short term, cycnical marketing move I've ever seen - pointless toss sold to idiots by shysters.
Having now ridden a couple I see no reason to modify that opinion.
I genuinely hope it fails, taking the careers and livelihoods of those responsible for it's promotion with it.
At least it's shown us the true colours of much of the MTB media - they'd promote a turd on a stick if the manufacturers told them to do so.
Posted : 08/01/2014 4:22 pm
theocb - Member
Though that was a continuation of the several times you simply said "most people have tried 650b", when we'd already called you out for that statement. It's almost like you changed your mind, eh?
theocb - Member
You can't just change a couple of variables but presume others are the same. If you run a lower volume tyre, you have to run higher pressure, which means higher rolling resistance-. And higher volume can be an advantage in its own right- a high volume tyre at low pressure provides more grip in some circumstances than a lower volume tyre with the exact same footprint, as it's more able to conform to rough surfaces.
High volume is a benefit thing in its own right, which is why going from a large volume 26er tyre to a low volume 650b tyre is not generally desirable, which is why you have to compare like with like.
Or, to put it another way- 650b and big tyres on 26 inch are not the same thing at all.
Posted : 08/01/2014 4:23 pm
😕 I never changed my mind at all. I double edited one of my posts to clarify within a few mins and before anyone had posted a reply and clearly noted it in my next post when I thought a couple of people had missed it (it's all there in black and white..)
Your version of rolling resistance is not one I agree with based on our discussion, we all know there are variables, which ones outweigh others is my point. You don't need to agree with me.. you have your own opinions based on your own skillz.
You are adjusting those variables to suit your version. There is a sweet spot range, I can't just run lower and lower pressures for better rolling resistance. A lower profile is not going to significantly alter that pressure range IME. The footprint will be similar or the same because it will be a similar width tyre on a 23 inch rim. Tyres conforming at 24 psi or 22psi is not a significant difference IME (I'm not a pro :0)
As I said, most riders have tried a basic level of 650b. Many Riders are very happy with their basic experience of this wheel size. A 23 inch rim offers some advantages over this basic experince and also some disadvantages
Make your choice. BUT..
A 29er rider in the blog saying that nobody had a clue how 650b will ride before buying is nonsense and the discussion evolved just like our bikes have.
They are very very similar with small differences regarding the advantages and disadvantages which I would say come down to the change in how we have used our bikes over the last decade. Evolution of the bike to suit our needs.. bless em.
It has gone full circle I'm just repeating myself. Now I have convinced you all it is not just marketing I feel that my work here is done.
Posted : 08/01/2014 5:27 pm
whoa there - that's a bit optimistic
I'm not convinced that so many people have test ridden 650b bikes
I do think the differences between 26 and 650b are really very small and that the blog in the OP includes some marketing BS, albeit pretty gentle, that bigs up the keenness of people to adopt 650b
Posted : 08/01/2014 5:48 pm
He told them so.
Posted : 08/01/2014 5:57 pm
Just watched the vid for 10 seconds, had to post this then I'll go back and watch it all and read the comments on here
But
"Don't feed the trolls" yes we may be angry or cynical, there's certainly more than 100 of us but us 'trolls' feed you.
Posted : 08/01/2014 6:12 pm
Both tyres below are 2.4 Trail King (Rubber Queen) fitted into Fox 32 Talas. Different rims, but same internal width plus/minus 1mm
Left is 26, right is 650b
Most comparisons and frustrations that I read are based on comparisons between big 26 tyres like the Rubber Queen compared to a 650b Pancetti Neo Moto or one of the smaller tyres that let the early adopters of the bigger wheelsize squeezed into frames designed for 26" wheels.
Big 26 vs small 650b makes little sense as a direct comparison as its not simply a case of striving for overall diameter. Think car wheels, a 15" wheel with a 195 tyre may be the same diameter as a 16" wheel on 205 series rubber, however there are different ride characteristics.
For example, the voltage FR below makes little sense to me.. squeezing a low volume 650b tire on the front of a gravity bike isn't going to improve anything. The builder is sacrificing the characteristics he really needs for the sake of it.
Yes, I want to build a Voltage FR with Fox 40 air and high volume 27.5 tyres front and rear... as that makes more sense than this:
For a gravity rider, high volume tyres make sense. For an XC racer, the larger circumference you can get might be the goal, but XC racers will tend towards achieving larger circumference with lower rotational mass hence the underground trend for 650b rim with low volume tire - that started before 29" wheels were on the mtb world radar.
Although, higher volume XC race tyres at lower pressure makes a world of sense in soem cases on race courses with a natural/technical aspect.
exactly.
/2p
Posted : 08/01/2014 6:40 pm
[quote=theocb ]A 29er rider in the blog saying that nobody had a clue how 650b will ride before buying is nonsense and the discussion evolved just like our bikes have.
Right, I think I understand your argument now. You're suggesting that the writer of the blog is wrong about people having no idea how a 650b will ride because they've already ridden something with much the same wheel diameter which rides just like a 650b. So if the reason these people know how a 650b rides is because it rides just like the bike they already have, why the excitement? Remind me again what the advantages actually are.
Posted : 08/01/2014 6:56 pm
theocb - Member
It certainly is:
theocb - Member
most riders have tried 650b and are very happy with that as a wheel size.
As you say, black and white, and talking about wheel size not effective size or tyre size as you later claim.
It's all as convincing as the idea that there's a load of 26 inch marketing teams out there with an agenda.
Posted : 08/01/2014 7:09 pm
The whole size thing is just another example of marketing push. The big brands get together and decide on what new specifications and standards they can come up with to make your current bike obsolete faster so you buy newer sooner.
It's no more than that.
The reason 650b seems so popular all of a sudden is just a fait accompli. The industry want's change, they know we will naturally resist it, so they hit a ridiculous bar with 29-ers. Not many people fall for it, but when the 650b is rolled out as the new messiah everyone is all over them because they aren't 29's but so much more like what we already know. Of course no one stops to think "then f_ck it, i'll keep what I already have".
Do the math, draw the diagrams a 29er is 8mm better at rolling over vertical objects than a 26" wheel. But at the same time that same wheel with the same built rim and tyre will be over 200 grams heavier and of course neither as stiff or as durable.
So if you like having to accelerate greater mass more often during every ride, go for it, knock yourself out buy some 29's. If not stick to your 26" and protect your investment in the bike you already own.
Posted : 08/01/2014 8:25 pm
Well, not more often really, since a heavier wheel is both harder to accelerate and decelerate right? And once it's rolling, 200g makes sod all difference to anyone except a world cup xc racer who hasn't got a good few kg of excess mass to lose himself.
Posted : 08/01/2014 10:13 pm
Funny that - the major bike companies have been extolling the virtues of componentry weight loss for years, however minor. 🙂
I don't remember them telling us it wasn't worth trading in our bikes for this years wonder model because we weren't good enough to notice the difference.
Posted : 08/01/2014 10:18 pm
Lighter is often good but it went too far, until recently people thought 17mm rims on an XC bike as a norm was fine because they're light. Seeing 200g more on an mtb wheelset as a real negative and basing a wheelsize decision on that is overestimating the effect of weight on a bike compared to other variables, but weight is easily measured and marketed. Balancing weight, tyre volume / contact patch abilities, wheel size, durability etc becomes tricky to wrap up and sell.
And yes most of us can get lighter and stronger ) Best way to do that is buy a new bike that makes you want to get out more eh? Step this way and check out these all-new wheels, they're french you know..
(tbh noticing stuff isn't related to being good on a bike, ime the opposite is often true, with my faster riding friends their ability overcomes minor stuff that makes me feel less confident)
Posted : 08/01/2014 10:34 pm
 nikk
Did you watch and understand the video? Santa Cruz say it is customer led.
Did you watch and understand the video? Santa Cruz say 60% of their sales are 29ers.
That would be true if everyone was running the lightest wheels and tyres and tubes / tubeless systems all the time. But they aren't. So sure, for the exact equivalent wheel / tyre / system, the bigger one will be heavier. But if you upgrade your wheel as well as moving to a larger size, the difference cancels out. Likewise by choosing a lighter tyre, lighter tubes, or whatever.
Also, you'd think the people that would really notice if there was an efficiency problem with 29ers, like for example the cyclists who do the Tour Divide, they wouldn't choose them. But they do, all of them for the most part.
I dunno what is to protect. You have you bike, go enjoy it.
There is a lot of worrying about stuff that hasn't happened yet. Sure, frame and fork choice for 26ers will get less, but you'll still be able to get them if you really want them. And if 650B does really take over and kill 26ers totally, well, your next bike will be a 650B. Sure, it is possibly added expense because you can't use your old tyres, but that's about it.
Posted : 08/01/2014 10:41 pm
I hope a lot of the haters stick to their words and actually give up mountain biking because of this wheel size issue.
I'm looking forward to the quieter trails. 😆
Posted : 09/01/2014 8:52 am
Singlespeed_Shep - Member
Who's said that?
nikk - Member
They're lying.
Posted : 09/01/2014 11:26 am
FFS is this still going on.
Three of us went out recently on a big 55k ride in the peaks. One on a 29er, one on a 650ber and one on a 26er. Which one was best ?
Couldn't tell you, because we just had a good day riding our bikes they way they should be rode !
Posted : 09/01/2014 11:39 am
a 26er, a 29er and a 650ber walk into a pub............
.......... what happens next?
Posted : 09/01/2014 11:41 am
A 26in with 2.5in "balloon" tyre fits my bike.
A 650b with slick, low profile 1.95in might just clear the front mech, but anything larger won't. A 2.1 Racing Ralph definitely won't fit.
Have I "tried 650b" ? 😉
Judging by what I've seen here, either lots of people have tried it and not liked it, or just haven't tried it. Still only ever seen one single 650b out on the trails (was in Aviemore). Only person around this way that I know of that bought 650b, sent it back unopened and swapped it for the 29er version.
Still think the best article I've seen was an MTBR (I think?) one where the outcome was that it picks up all the compromises of 26/29, unlike 99.999% of all articles that say it gets the best features of both.
Posted : 09/01/2014 11:44 am
I've got a 26 HT, a 26 FS and a 650b FS. Which one is best.... ?
I'll be ****ed if I'm telling you lot !!!
Suffice to say I like riding mountain bikes on trails and mountains and enjoy all three though.
Posted : 09/01/2014 11:54 am
Who's said that?
No one in particular in this thread but the impression is there from people attitudes, It has come up in other wheel threads.
They're lying.
So they built a bike no one wants?? and forced people to buy them?? 😆
Posted : 09/01/2014 12:06 pm
This isn't true though, is it? Have you tried a 29er or 650b? Do you really believe 26" is the exact sweet spot and nothing else could offer more?
To suggest 29ers are simply a marketing exercise tells me you've never riden one. I've got one and am undecided if I prefer 26 or 29 but they are very different and offer options that were not there before. That's good in my book. 650b will be different again no doubt.
Always good fun seeing these threads on here and seeing people get so over excited about something that has not caused them any problems so far. You can buy 26" bikes, forks and wheels still and will be able to for ages. I bet you will still be able to get them for longer then most of the grumblers keep their current bike.
If the wheel, fork and frame makers think they can sell loads of 26" gear they'll keep making it. Why wouldn't they?
Posted : 09/01/2014 1:35 pm
 chip
Not the good stuff you won't. That is if the rapid demise of the 1-1/8 steerer is anything to go by especially with a 15 mm through axel.
If people stop making new 26" wheel mtbs they will stop making new 26" forks.
A few models may continue to get made in there current never evolving spec.
Posted : 09/01/2014 2:00 pm
In fact as usual there is a little more too it than the actual wheel size,
1. longer wheel base on a pro rata basis gives more stability
2. lower BB to axle ratio giving better cornering stability
3. longer front centre (for most part) which give more confidence in fast or steep or technical downhill or all three
4. whatever the claims that the wheel size confers in roll over ect.
incremental change that probably improve handling characteristics, all a matter of personal taste, but if you cannot tell the difference between a 650b and a 26er (in full sus) then its probably not worth making the fuss about rear suspension designs either!!
So you could get all three parameters on a 26 er apart from the no 2, which to achieve with 175 mm cranks may be tricky.
Posted : 09/01/2014 4:52 pm
[quote=nikk ]Did you watch and understand the video? Santa Cruz say it is customer led.
Mandy Rice-Davies applies.
Posted : 09/01/2014 5:27 pm
Most manufacturers cant risk producing both 26 and 650 of the same model, hence the turning point was when suspension, wheel and tyre manufacturers committed to high volume 650b output, it was then an easy decision for the likes of SC to make. Its purely a numbers game and given the interest the likes of SC already had with regards to 650b it was less of a gamble than some other manufacturers.
As SC led the way, they have probably reaped the most benefit in 2013/2014 but the others will catch up this year and next.
Santa Cruz hasn't led the way with 650B, they've squeezed in a couple of frames with the new wheel size into their range this year, as have the other smaller high-end brands such as Yeti and Orange. The likes of Giant and Scott have wholeheartedly jumped onto the 650B bandwagon and account for far more sales than Santa Cruz et al.
It's both industry and customer led, neither can create a market for a new standard on their own. If demand is there then companies will produce the bikes and components people want; whichever of the three wheel sizes survives will purely come down to economics in the end however we feel about it.
A majority of mountain bike sales are to the beginner / leisure market around the £400-£600 price mark, to these buyers it's just a bike regardless of wheel size and they'll buy whatever the shop has available or what MBR/WMB are pushing at the time; if those bikes are 650B we have little control over that.
Personally I'm happy with 26 and 29 which both offer something different. I'm not sure my opinion will count for much in the wheel size war though, but a small battle will be own for me in not jumping on a shiny new 650B for the sake of it. 😀
Posted : 10/01/2014 8:36 am
To be fair they've done a touch more than that. There are 4 frames in their range that are 27.5; 6 including the carbon variants.
As the guilty party responsible for starting yet another thread about wheel sizes, the point from the article that I wanted to note was how quickly this has all happened. When I was shopping for my latest bike - end of the year 2012 - only Scott had a 650b/27.5 bike. I never expected it to take hold as quickly as it has done.
Posted : 10/01/2014 11:53 am
Nobody's said they'll do that, that I've seen? 😕 But there's definitely people who've been put off buying stuff. I'd probably have bought a new frame last year but didn't want to buy the new wheels, tyres and forks needed to switch standards, so instead I spent it on hookers and blackjack.
I'm really curious to find out how this all shakes out in the end. Some manufacturers will do well from it, but since it'll not get a single extra person riding bikes, it's a bit of a tail-swallowy exercise.
So it'll be interesting to see if in 5 years once the dust's all settled it proves to have been beneficial. There'll be lost sales, gained sales, extra r&d, more marketing costs. A lot of money spent to stay in the same place, in some cases, or even to slip behind competitors. Some lost opportunities- every penny spent developing a 650b equivalent of a 26 inch product could have gone on something new and cool. I think a lot of the industry will curse it. And riders... We'll just keep riding like we did before, with less money in our pockets
Paceman - Member
Eh, Giant have been one of the slowest to jump on, with obvious reluctance. Whereas Santa Cruz's entire marketing and design push has been on 650b since early last year (or maybe earlier, behind the scenes)
Posted : 10/01/2014 11:58 am
Yup I've also been contributing to the pro-650b stats by not buying a 26er.
Sales of 26ers dropping off is because of people like me holding back for 3 years to see how it pans out, and not because I'm waiting for 650b.
For which, I do apologise to the pro-26ers, for screwing up availability of new 26ers.
Posted : 10/01/2014 12:02 pm
As i posted in a response above. not a direct response no anyone in particular but its the impression i get from peoples attitudes and from speaking to a few people out on the trails.
I do think your right that people are more likely to hold off. As just riding a bike is more important than a wheelsize.
Posted : 10/01/2014 12:19 pm
interesting thread. im in the market for a new bike. Everything im looking at this year is 27.5 i dont think we will have a choice as to whether 26 will be around in the numbers it has been in the next couple of years. Its a shame.
Posted : 10/01/2014 12:43 pm
Paceman - Member
Northwind - Member
[b]Current UK MTB ranges:[/b]
[b]Santa Cruz[/b]
26er x 7
650B x 6
29er x 7
[b]Giant[/b]
26er x 3
650B x 11
29er x 4
I'd say Giant are pushing 650B pretty hard wouldn't you? Their only 26ers are a £450 entry level hardtail and their £5000 DH bike. They also stated in their press launch at the start of the year that they will drop any wheel size next season that isn't selling. Writing on the wall I think 🙁
Posted : 10/01/2014 1:04 pm
Quick search of CRC shows plenty of 1 1/8th forks with 15mm axel as long as you don't want Fox. You can't get every fork but you can still get decent ones.
I'm sure part of the reason for the drop off in 1 1/8th was that the sort of people who drop ££££££ on the s****y top end forks are also the type that would have bought a s****y new tapered frame and s****y new 15mm axel wheels when they became the standard. Didn't seem to matter as much then though. 😉
It the people who made the gear thought they could shift what ever standard you care to mention then they would make them. It makes no sense not to.
Posted : 10/01/2014 1:35 pm
The smaller companies are gambling less in many ways - its the bigger ones who seem to backing just one horse. Giant are putting all their eggs in the 650b basket (more or less) and Specialized on 29er. One of them is going to have to change a lot in the next two or three years and look silly.
I'm just hoping that companies aren't going to replace 29 as well as 26 with 650b - I'm lanky and like my big wheels!
Posted : 10/01/2014 1:44 pm
 GEDA
Can we not like all wheel sizes and spread the love? I must admit I bought a 29er and think it is great but don't ride it as much as I should as most of my time these days is spent building and riding jumps, pump tracks and drops as that is what I have decided I will "improve" in my riding.
Smaller wheels mean smaller/stronger frame, greater manoeuvrability, greater acceleration. But most people who go mountain biking are not doing this kind of thing and from looking at most of the trail centre trails they are smooth, swoopy affairs so these characteristics are not so important
Posted : 10/01/2014 1:57 pm
Paceman - Member
They are now- like I say, very late on the boat, they were pushing 29ers as the best option until about 5 minutes ago and trying to replace their 26 inch range with those.
Posted : 10/01/2014 2:28 pm
I'm in the market for a new FS at some point this year and up until now i've been fairly ambivalent to the wheels size issue, deciding that i'll get whatever is best for me at the time and if it has 26 inch wheels, 650b or 29 inch wheels then it really doesnt matter, its the bike as a whole, the reviews it gets, price, how it fits me etc etc...
....then i started looking at the price of 650b parts, jesus wept.
I'll not be going 650b for a while yet!
Tyres from all manufacturers in all tread variations are plentiful and cheap in 26 inches...the range for 650b is limited and the prices are much much higher.
Forks nearly made my eyes water, there are loads of Revelations and Sektors at very reasonable prices in 26 inch form but start looking at 650b specific forks and the price shoots up dramatically....i'm starting to side with the skeptics and feel this is a massive marketing push and nothing more.
On the basis of the ridiculous price premium the manufacturers have put on 650b specific gear i'll actually wait this year out and see if prices come down and if 26 inch stuff really does become difficult to get hold off as the doom mongers are saying....because actually the reverse seems to be true and its the 26 inch stuff that is currently plentiful and cheap.
Posted : 10/01/2014 2:29 pm
I've not looked but would guess it's not 650b stuff being any/much more expensive RRP but more that every one has got used to and expects big discounts (CRC/Merlin/Wiggle etc) so are not used to paying RRP. From what I understand the big discounters tend to stock a lot of OEM or slight seconds so as 650b stuff floods the market it'll be that stuff that gets the biggest discount.
People will be cheesed off about the price of 26" gear in the future as the discounters will not get the same stock. You'll still be able to get it though.
Again without checking, I'd bet the price of 26"/650b/29er equipment at my lbs is very similar
Posted : 10/01/2014 6:28 pm
Cant say i've ever bought tyres from my LBS due to the ridiculous RRP being charged....i tend to order tyre online and a quick google shows the Maxxis Highroller 2 in 26 inch flavour at around £30, rising to £40 for the 27.5 and 29 inch versions....it wont break the bank but for those of us with mud tyres, soft compound tyres, XC tyres, dual ply DH stuff etc etc the price difference soon adds up....enough that over the course of a year a 650b would cost me loads more to run than my current 26 inch bike on tyres alone.
Until the price of consumables comes down then i'll wait, once the market is flooded with 650b stuff and the price comes down i'll change over....this is one of several hobbies i have and the idea of spending £40+ for a tyre is a joke, the tyres on my car didnt cost that much!
Posted : 10/01/2014 6:41 pm
Don't disagree at all. Seems that 29ers will remain a strong minority so stay high but if the push for 650b continues that will become the cheap option.
Posted : 10/01/2014 6:53 pm
For the sort of riding I do I was always going to go 29er with my next bike (whenever that might be), so in a sense some of this is irrelevant - though I'm guessing that 650b may take away some of the 29er market (was probably looking at a Giant, which might not exist in 29 form by the time I come to buy, but given their marketing I'm not sure I could bring myself to buy one now anyway, so that's one sale they've lost - I doubt they'll be crying). Still don't think it's in any way a good thing for the consumer.
Posted : 10/01/2014 7:14 pm
recently bought a 29er...shit maybe I should have gone 650...dam
thats what you'd like me to say 😆
Posted : 10/01/2014 7:55 pm
Page 2 / 2
