6 toolbox heroes (a...
6 toolbox heroes (and one villain)
 a11y
Posted by: BadlyWiredDog
I also own a Cushcore bead dropper, which is kind of a Pedros lever on steroids with a nice rounded handle so you can push the bead down into the central well of the rim pressing down at 90˚ to the sidewall. Does exactly what's it's supposed to, but didn't make a dent in the horrible welded, 'you can stand on me, but I'm not budging' tyre/rim combo.
Similar to my experience with the CushCore bead dropper tool on a tennerager-level-stubborn tyre/rim/insert combo: Conti CrossKing/Reserve 30HD/CushCore. Took more force than I was happy applying to get the bead off, involving a combination of inappropriate tools from around my garage. I'd not stand a chance of removing the tyre trailside if something happened.
Posted : 12/11/2025 9:30 am
 a11y
For anyone looking for the Vittoria tool, this might be worth a look. Doesn't specifically state it's the MTB version although that's what's pictured (the box at least has 'MTB' on it) and no mention of the 6 tyre lever things. £12.99 vs the ~£25ish it is most other places: https://www.decathlon.co.uk/p/pliers-and-tyre-lever/_/R-p-X8910022
Posted : 12/11/2025 9:34 am
 nbt
Posted by: IHN
Fair enough, I'm a whip the thing out, slip in my length and empty my load kinda guy.
He's not called "One-shot" for nothing y'know
Posted : 12/11/2025 9:53 am
I (re)use the little bottle of Stans. It fits into the top of the stans tubeless valves, and is about the right amount. Just pop my finger over the end when I'm tipping it up
Posted : 12/11/2025 10:31 am
chrismac reacted
Never found an issue with Wera hex or Torx wrenches.  Use the ball end for low-torque just spinning the bolt and then nip up with the other end and check with a torque wrench.  Not rounded a bolt head or wrench in the 5 years I have been using Wera wrenches.  Have to admit I am mechanically sympathetic and look after tools.
Nail clippers as mentioned above are great for cutting zip-ties.
Tyre fitting tools have moved on so much since I have been riding.  The Vittoria tool and a Tyre Glide have made a great difference - especially with tyre liners and poor rim and tyre combinations.  My thumbs thank the inventors of these!
Chain link pliers - made joining or splitting a chain at the split link so much easier!
Cable cutters.  Nothing has beaten the old Suntour ones I lost 😭.  The Park ones are ok - but just not as good.
Posted : 12/11/2025 2:11 pm
Posted by: tthew
Most used tool in my tool box – Knippex plier wrench.
Also the best tool I have for resetting brake pistons. Parallel action and smooth jaws work better than any other of the various tools I've tried over the years.
@tthew how do you do this? I can’t picture how this would work. (I’ve got a set, one of my favourite tools)
Posted : 12/11/2025 2:34 pm
£20 quid for the Muc Off tool? Just use an Allen key bit wrapped in some gaffer tape.
Posted : 12/11/2025 2:54 pm
Posted by: joebristol
Maybe I just need another set essentially the same but with normal ends on as it would be useful to have both
Yeah Wera do both types, I have them
Posted : 12/11/2025 3:01 pm
Page 2 / 2
