6-bolt to centreloc...
[Closed] 6-bolt to centrelock rotors?
A world of pain or should I just get some 6-bolt rotors? Are all adaptors created equal?
(I've got some 6-bolt wheels and some centrelock rotors)
Posted : 15/05/2017 8:37 am
I have never tried them but the reality is you can get rotors for about the same price and that is what I have always done- perhaps adaptors are cheaper now than when i last looked?
Posted : 15/05/2017 8:40 am
Evans do good six bolt to centre lock adaptors
Posted : 15/05/2017 8:41 am
Unless I'm reading your post wrong - you cant get adapters that will make a centre lock rotor fit a 6-bolt wheel as far as I know.
Posted : 15/05/2017 8:42 am
I didn't think you could put centre lock rotors onto 6-bolt wheels.
You can get adaptors to put 6-bolt rotors onto centre lock wheels.
Posted : 15/05/2017 8:44 am
I've got DT ones in one bike and an Ashima in another, they've all worked great- though I know some people haev trouble with getting tools to fit, mine were all fine. Meant I could use old rotors in one bike and my choice of pimpy lightweight ones in the other.
As above, it is not possible to fit CL rotors to 6-bolt hubs, only the reverse (6-bolt rotor on CL hub).
aye yes he is correct you get centrelock to 6 bolt adaptors you wont get the others as the hub will be in the way, it wont be possible
Posted : 15/05/2017 8:45 am
Oh! Yeah I didn't read that right either
Posted : 15/05/2017 8:47 am
Ah Ok problem solved then!
Posted : 15/05/2017 8:48 am
