456 Summer Season G...
[Closed] 456 Summer Season Geometry
Just got my new On One 456 Summer Season built up and took some time measuring angles and stuff for future builders.
The frame is 16" and fitted with a pair of old but plush and reliable Boxxer 151 forks 6" forks.
First off I measured the lower fork crown race face to the centre of axle and compared it to my sons Marzocchi DJ3 100mm forks.
Boxxer = 520mm
DJ3 = 495mm
So a Boxxer 151 is 25mm longer than a 100mm DJ3.
This is due to the Boxxer having a thinner/lower lower crown.
The head tube angles are as follows:
66 deg with fork at full extension (no rider)
67.5 deg with 40mm sag (with rider)
72.5 deg with fork at full compression (springs removed).
So Brant`s predicted 1 deg change of head angle for every 1" of travel holds up (did I ever doubt him).
It also shows that a Boxxer 151 will give 150mm of travel for a 25mm gain over a 100mm fork.
Posted : 07/12/2009 8:41 pm
