44mm headset
[Closed] 44mm headset
[#3936233]
44mm headset!
Does anyone know who else sells these??
Hope & Cane Creek too expensive and Nuke proof are fully out until next month!
Posted : 02/05/2012 6:39 pm
Think this does the trick for £20 - edit - £27, even
http://www.chainreactioncycles.com/Models.aspx?ModelID=15888
Posted : 02/05/2012 6:44 pm
Hi
thanks for that,
I wasnt sure if that would work or not. Basically have a Ragley Blue pig and it says a 44mm standard headset. I know this is a 44mm internal but does he 50mm external mean it'll be too big??
Posted : 02/05/2012 7:13 pm
50mm is the outside diameter of the head tube, as far as I know - 3mm think sounds about right. That said, headsets are such a minefield that it's worth checking first - but having fitted a 44mm one last week (Hope) it looks right to me.
Posted : 02/05/2012 7:33 pm
which hope one did you use?
Posted : 02/05/2012 7:36 pm
I bought top & bottom cups separately, 2 & B from below
Posted : 02/05/2012 7:44 pm
Thanks for that.
I make the outer of my frame 48mm so that would leave a tiny (1mm lip) with the FSA but the internal size should fit fine.
The hope bottom cup is out of stock as well!!
Posted : 02/05/2012 7:54 pm
I think Superstar Components do a 44mm semi-integrated headset.
Posted : 02/05/2012 9:08 pm
