42 cog noise on sra...
[Closed] 42 cog noise on sram x1 cassette
anybody had just this gear make strange noises? all my other gears shift and make no noise (not even griding in the peak grit), bar the 42cog
I'm running a absolute black oval chainring, kmc x11sl chain and x1 cassette/xt 11speed rear mech, chain length fine, b-tension fine etc
all shifts are crisp etc, but when wynching up long slogs if I use the 42c it makes a kind of pulling/jumpy type noise just in the 42cog, drop down the next and instantly goes, its there every other revolution and as said its like a jumping/pulling type noise (as though it sounds like it skipping but actually doesn't)
any ideas? its a fair old mix of brands/components though I'm 99.9 sure it didn't do it when I first had it all (don't really use the 42very often)
Posted : 30/12/2015 2:22 pm
the 42 is pressed onto the rest of the block, at a guess there is a small amount of movement? movement = noise
Posted : 30/12/2015 2:30 pm
It the sound of your inner self acknowledging that you need to mtfu and use a smaller cog.
Hth
Posted : 30/12/2015 2:31 pm
ive not looked at the cassette as such (other than theres no movement on the hub)
will investigate the 42 cog itself, though its relatively new so not something Id thought of,
its very odd, it almost sounds like something pulling/yanking at the jockey wheels, like its jumping, but everything routed correctly
tbh since its been doing it ive used it even less as it almost feels a bit vibrating through the saddle
Posted : 30/12/2015 2:36 pm
Theres a few on here who'd like it vibrating in the saddle....
Posted : 30/12/2015 2:41 pm
b screw?
Posted : 30/12/2015 2:42 pm
tried the b-screw yesterday, wound it right in so it was almost touching (buggered up gearing) but noise still there
and then wound it out as far as i could and still there
worth noting its also suddenly when backpedalling dropping down the cassette, something it definitely didn't do a few weeks back?
Posted : 30/12/2015 2:48 pm
hammyuk - Member
yeh I'm very sure there is ๐Ÿ˜‰
Posted : 30/12/2015 2:49 pm
ah is it the clutch?
Posted : 30/12/2015 2:52 pm
ive had the clutch apart before and it was making a racket, but a re-grease cured that, however this makes the noise with the clutch engaged or not so not really thinking its that this time
Posted : 30/12/2015 2:57 pm
Sounds like the indexing/limit screw at the top end may be a little off. Have you dropped it recently? Slight bend in the gear hanger possibly?
Posted : 30/12/2015 4:08 pm
Is the limit screw set right ?
Posted : 30/12/2015 4:44 pm
This I'd say
Posted : 30/12/2015 4:55 pm
Chain alinement ? I find the AB chain rings don't have enough dish so when your in 42 the chain is pulling across a long way. Ive had to use a crank set with a 163 q factor and space the bottom bracket over to get it right
Posted : 30/12/2015 5:02 pm
Don't think the hanger is bent tbh, it s shifts absolutely perfectly in every gear even the one in question
Assuming your mean the limit screw for the low(42t) cog? Could have knocked it I guess though it shifts in and out of it ok but could well be as its suddenly started dropping when back pedalling so I'll take a look at that
It's nowt major just prefer it to not be making the noise it does sure it's an easy fix
Posted : 30/12/2015 6:47 pm
Chain alignment i did think but it doesn't make sense that it was fine when all put together and running fine and nothing's changed on it as I've used the ab ring for over a year now
Posted : 30/12/2015 6:49 pm
Your set up is very similar to mine and the only other time i have problems is when the chain gets very mucky with old oil build up, it gets clicky and noisy and a good clean with degreaser sorts it out. But thats usually across the full block.
Mike
Posted : 30/12/2015 7:22 pm
Is the ring over a year old? What sort of milage has it done? How old is the chain? Maybe it's wear and tear and only apparent on the 42 as it's the most extreme chain angle?
Posted : 30/12/2015 8:16 pm
No sorry meant I've been using the ab chainrings for a year but had a few not the same one, this ones about a month old with a new X11 sl chain and X1 cassette again all brand new
No noise at all new, no noise at all in any other gear apart from 42t
I'll have a look at the low limit screw as it would make some sense as to it now falling off back pedalling
Posted : 30/12/2015 11:04 pm
Chainline is my guess but also check know the me how is done up right mine unwound until I popped some loctight on it
Posted : 30/12/2015 11:19 pm
 gee
Either a bent hanger, dodgy chainline or limit screws.
Posted : 31/12/2015 9:35 am
cheers guys, will have a look at the chainline, hanger and limit screws then ๐Ÿ™‚
Posted : 31/12/2015 10:40 am
I find setting up the spam 1x11 is a nightmare I just can't seem to get it right
Posted : 31/12/2015 10:57 am
Bent mech hanger, limit screw, bent tooth on the 42, gunked up chain, stiff links in chain, worn or stiff or gunked up jockey wheels. The list is endless.
Take the chain off and give it all a good clean, then setup from scratch, starting with the mech hanger.
Posted : 31/12/2015 11:24 am
was also going to add, when I'm on the flat or minor incline it doesn't make any noise (or in the workstand) in the 42t cog in question, just when climbing steep when its needed
not sure if that would be todo with chainline then?
Posted : 31/12/2015 1:20 pm
 gee
Yes it could be - the extra torque put through it when ridden up a hill makes it make that noise when chainline is a bit extreme.
Posted : 31/12/2015 3:27 pm
