4 blokes & 4 bi...
[Closed] 4 blokes & 4 bikes in a Mondeo hatch. Possible?
What do you think ?
Or a two car jobbie...?
Posted : 23/09/2009 10:37 am
You're gonna need a bike rack!
Posted : 23/09/2009 10:38 am
Three blokes and three bikes is the max I reckon, two on the rack, one in the boot - with the 2/3 seat portion down.
Possible you could get three on the outside and one in the boot if dismantled and if you didn't have much luggage. Think you're looking at two cars really though.
Posted : 23/09/2009 10:40 am
 Doug
3 Bikes on a towball rack and one in the boot with it's wheels bungied to the bikes outside with a bit of padding to stop them rubbing.
3/4 on the roof and one in the boot using the same wheel trick.
2/3 on the roof and 1/2 on a normal boot rack.
If your going a long way take the forks and mech off the one in the boot to get it to fit across rather than folding a seat.
Posted : 23/09/2009 10:42 am
You'll probably get 2 in the boot with the wheels.
Posted : 23/09/2009 10:45 am
 StuF
You could get 4 on the roof rack without too much problem. I guess it's down to how much kit you've got with you.
Posted : 23/09/2009 10:48 am
i went with my mate in his 3 bikes in the car with bags and 3 blokes . but have to have the 60 bit of the rear seat down. not gonna get four and four blokes inside . i carry 4 bikes on my roof on mine 😉
Posted : 23/09/2009 10:49 am
 luke
it would be a squeeze but i reckon you could do it with a bit of dismantling and removing the parcel shelf.
Posted : 23/09/2009 10:50 am
3 bikes and 3 blokes with way too much kit (including food and 3 camping stoves) in a Focus hatch so I would at least give it a go. Oh and full face helmets with a bit of armour and changes of clothes.
Mondeos are a fair bit wider than foci so depending on the bikes you could possibly get them all standing or lying in the boot. The wheels could fit on top and on the back seat if you kept the kit levels to a minimum. Obviously the kit would go on laps and in gaps around the bikes.
Posted : 23/09/2009 11:12 am
should be ok
Posted : 23/09/2009 11:13 am
I think you'll be lucky to get 3 in tbh and it'll be a lot of a squeeze - i can just about get 4 guys and 4 DH bikes (wheels and pedals off) and 4 guys kit for a day in the V70 and that's pretty tight....
Posted : 23/09/2009 11:19 am
We went for 5 + bikes in an Imprezza, got everything on/in but bottomed the suspension out to the point that it wasn't safe to drive. Gutter.
Posted : 23/09/2009 11:28 am
 Sim
I tried to get 3 people and 3 bikes in my Mondeo and failed. The reason? Whilst the back of the seats in the rear splits the actually bit you sit on doesn't. Which just doesn't make sense, but there you are. Don't know if it's just mine…
I can easily get 2 bikes in the back of mine, including wheels and with the parcel shelf in situ. 3 without shelf and using the 2/3 split should be pretty OK with kit. I don't see you'll manage 4 without a rack. 4 easy with 2 on a rack though.
Posted : 23/09/2009 11:31 am
Drove to Morzine with 3 blokes and 3 bikes, plus assorted kit, tools, and a bike stand, all inside (although it was an estate) Tight squeeze, mind.
Posted : 23/09/2009 11:32 am
It's dead easy if you have a sealed headset just take the forks/wheels and seatpost off. Frames on boot floor, wheels standing on frames, everything else where you can fit it. Depends where you are off to but putting it all back together will a few minutes and you can tank along the motorways no worries.
Posted : 23/09/2009 11:42 am
Sim, no, mine's the same. Daft idea. I still reckon 3+3 is doable though.
Posted : 23/09/2009 11:45 am
If you are not going to bin a friend and you are not going to put stuff on racks outside you will need 2 cars.
Posted : 23/09/2009 11:53 am
 smeg
Did a Les Arcs road trip in a mondeo this year, 3 of us & 3 bikes in a Mondeo hatch. Pedals off, wheels off & bars turned & the bikes took up surprisingly very little room, the wheels were the biggest pain. Also had a roof box for luggage.
If you've got a roofbox to put wheels & luggage in then reckon you'd do 4 + 4, wouldn't do it for a long journey though.
Pedals and forks off you will, just! (as long as its not 4 XL frames)But a tow bar or roof rack will make a big differance. I'd go for a tow bar mounted rack, i'm 6'1" and a bike on a rack on the roof of a Mk3 mondeo is a long way up.
Posted : 23/09/2009 11:59 am
I've not found the unsplit bench seat to be a problem, the seat back will fold almost flat over the seat cushion.
If you could tilt the seat cushion forwards you'd get a few inches more height, but you lose the space in the footwell which is ideal for bags/shoes/helmets.
In my old car the backrest couldn't physically fold forwards over the seat bench, but with the bench folded forwards the boot was too short. So I ended up unbolting it and chucking it in the loft 🙂
Posted : 23/09/2009 12:24 pm
53 plate Mondeo Estate for sale here, approx 65k, 4 blokes 4 bikes no problem. Tis the fast TDCi 130 version as well 🙂
Posted : 23/09/2009 12:26 pm
With a boot lid/tow ball mounted rack I reckon It ought to be doable
Fold one rear seat down and try to get two frames alongside (with wheels/seatposts removed). I've done it in a laguna hatchback
Then Two (complete bikes) on the back perhaps with 2 wheels from one of the inside bikes
Luggage plus 2 wheels in the remaining boots space
Else 3 complete bikes on a rack and one frame/fork on the one folded down seat?
Posted : 23/09/2009 1:15 pm
