3x9 inner ring repl...
[Closed] 3x9 inner ring replacement. New ring isn't quite the same (no recesses)
I've bought a new inner ring to replace the old one. Both deore 9 speed
But the new one is flat whilst the old one has a slight recess where it meets the cranks. The new ring will be slightly be more further out by about 1mm
Will this matter. I could stick the old one back on its not that warn (compared to the middle which was well on the way out)
Posted : 01/11/2014 12:12 pm
OK that's 1 mm further inboard
Posted : 01/11/2014 12:46 pm
No I now conclude the new ring is a touch thinner and all will be fine
Posted : 01/11/2014 1:04 pm
Is everything else the same?, is everything else the same or could the 1mm be made up elsewhere? Moving the limit screw might make up/accommodate the difference albeit with an increased risk of dropping the chain between granny and middle. Couldn't guess how much more of a risk though.
Edit-wish I typed 42 seconds quicker ๐Ÿ™‚
Cheers tracker
I still need to fit the chain which I'll do tomorrow
But it all looks fine at the moment
Posted : 01/11/2014 1:35 pm
