2x10 - worth it?
[Closed] 2x10 - worth it?
 PJay
if you've got a perfectly usable 3x9 setup?
I'm really enjoying my bike at present and really fancy spending some money on upgrades, the problem is that it's pretty much how I want it already. I've got an XT 3x9 drivetrain that's working perfectly and have been toying with the idea of going 2x10, but is there really much point? I appreciate that eventually the lack of quality 9 speed components will force my hand but currently I don't have cash to throw away so am wondering whether it might be better saved for something else later. Will 2x10 really offer me anything over 3x9?
Posted : 01/07/2013 8:47 pm
I would say its not worth changing for the sake of it, but I wouldn't go back to 3 x 9 or buy a bike with 3 x 9.
Posted : 01/07/2013 8:54 pm
having gone to a double and now a 1x10 , of say give 1x a go
Posted : 01/07/2013 8:57 pm
 jruk
I've just gone from 3x9 to 2x9 and haven't missed the top two gears I've 'lost'. Just stuck a 36t on the front with some shorter bolts, lowered the front mech about 20mm and screwed the upper limiter in and job done.
I'm sure I'll change to 2x10 at some point but I can't see the point in ditching perfectly good XT mechs and shifters.
Posted : 01/07/2013 9:18 pm
Don't worry about 2x10, just do 2x9 with bash ring. RaceFace were doing an Atlas kit of 24/36/Bash for about £80.
Posted : 01/07/2013 9:21 pm
If money is an object do what DiscJockey says and save the £300 plus it will cost you for a whole new chain set for a new bike with the spec you want!
for your ref.. I have gone 3x9 to 3x10 to 2x10. For my riding 2x10 and a chain guide is my sweet spot. It was not a cheap journey though.
Posted : 01/07/2013 9:30 pm
 jruk
If you don't want a bash (I didn't), I used [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=38189 ]this 36t[/url] and the short version of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=35866 ]these bolts[/url].
Posted : 01/07/2013 9:32 pm
Hijack, i have a sram x0 2 speed shifter and a 2 speed front mech should you go that route
Posted : 01/07/2013 9:59 pm
 MSP
a 2x10 and a 3x10 with the big ring replace by a bash guard are not the same thing. A 2x10 has a bigger jump between the chainrings.
3x9 22-42-42
3x10 - 24-32-40
2x10 - 26-38/28-40
Personally, I like the 24 granny ring that comes with a 3x10 as opposed to the 22 that comes with a 3x9, It saves making a correction change at the rear when you change down at the front. I also like a 11-32 cassettes as I don't like big jumps between gears, and don't want to go 11-34/36.
Posted : 01/07/2013 10:10 pm
 br
Yes, throw your old worthless 3x9 in my direction 🙂
Posted : 01/07/2013 10:14 pm
Did exactly what you're thinking about. Had the chance to spend whatever I wanted on my bike, so went XTR 2x10 just because I could. Got 40/28 front and 11-36 at the back. Spend 90% of my time in the big ring, and mostly it's made sod all difference to my riding. Hills are still hills (if you know what I mean) takes a few rides to get used to different ratios. It's obviously less faffy than 3x9, but it's not earth shattering
1 x 11 is where its at, and with xo1 stuff coming out and undoubtably shimano doinga challenge, i'd do this. Even a 1 x 10 would be ideal, if you could get a 10-36 cassette with a 32 front
[i]if you could get a 10-36 cassette with a 32 front [/i]
and pointlessly spinney...
Posted : 01/07/2013 10:18 pm
You might want a shadow plus mech (10 speed only). Though I reckon they are bit over hyped. I fitted one on my 2x9 by using some used sram shifters.
Posted : 01/07/2013 10:44 pm
Only real benefit of 10-speed in multi-ring setups is the clutch mech IMO
Posted : 01/07/2013 10:49 pm
how so? a 32-10 you could get up to 30+mph and a 32-36 could handle all climbs needed
Posted : 02/07/2013 12:49 am
 JoeG
If you don't already have one, buy a dropper seatpost! That will change your riding way more than 2x10.
Posted : 02/07/2013 1:32 am
I don't see any point in moving from 3x to 2x. The benefit for me in going to 1x was reduction in complexity and gubbins on your handlebar. going to 2x from 3x doesn't do that. You may as well jump straight to 1x and be done with it. I've gone for lower ratios which mean I do miss lower gears on flat tarmac or gentle descents, but I tend to do 90%+ of my riding in the lower gears as it is quite hilly where I am and the descents tend ot be steep enough that you don't want or need to peddle down, so just use those occasions to relax, coast and enjoy the scenery.
Posted : 02/07/2013 8:02 am
 br
[i]and a 32-36 could handle all climbs needed [/i]
What? Based on the folk I see on even trail centre climbs (Sunday at Innerleithen XC for example) using their granny rings, I doubt it.
Posted : 02/07/2013 8:09 am
wobbliscott - Member
Better chain retention and ground clearance mainly, and a little less weight for very little loss. Also less likely to get a chainring in the leg, though how often that actually happens I don't know- it's grim enough when it does happen to get people's attention though!
b r - Member
Mmm. I use my granny ring on the bikes that have them, but that doesn't mean I need it. But by and large I agree, 1x10 works fine for me in most circumstances but then I am not averagely bikefit, let alone below averagely fit like 50% of riders. And even then, sometimes it's not much fun. (people obsess about short steeps, those are fine, it's long grinds)
1x11's a step up but I still wouldn't want to put my brother on a 1x11 bike for a decent sized ride...
Posted : 02/07/2013 8:16 am
The thing is your 9 speed XT is still perfectly good kit but relatively worthless now if you are flogging it on to help fund an "upgrade" to 10 speed, I suggest you just ride it into the ground first and then see what toys are on the market...
Personally I'm going to hang on for at least another year using 2x9 and watch the new stuff coming out, there seem to be staggered development cycles from both big MTB drivetrain manufacturers these days, hoping on any given bandwagon today typically seems to mean that in six months another "newer, better" thing arrives...
So I'll see how far SRAMs 1x11 kit filters down their range and what sort of freehub compatability it has, as well as seeing what shimano come up with as an answer to that 10-42t cassette...
My feeble legs require slightly more range than a current 1x10 setup would provide and 2x10 ain't that different from 2x9 really, so I'm sticking until something comes along that really makes me want to twist...
OP - Save for when something really whizzy comes along or if you have to Spend the money look at other posh bits maybe a dropper, fancier forks or some carbon bars?
All IMO of course...
Posted : 02/07/2013 9:50 am
