2x10 to 3x10 - how ...
[Closed] 2x10 to 3x10 - how many additional chain links
As per title, going from 2x10 (38 tooth outer) to 3x10 (24-34-42).shimano, how many additonal chain links do i need on my new chain over the original?
Posted : 24/10/2014 8:38 pm
I'd go for one extra inner and one extra outer plate. Logic being half of 42 minus half of 38. Might be worth measuring it properly tho.
Posted : 24/10/2014 8:50 pm
Well the general measure is to wrap chain around the 2 largest gears. Assuming rear stays the same you would need to account for 4 extra teeth so 4 links more
Posted : 24/10/2014 9:15 pm
The chain only wraps round half the ring hence I reckon you only need to account for 2 extra teeth. Not saying I'm right but that's my opinion.
Posted : 24/10/2014 9:39 pm
Also going from 36 max to 34 max on rear... xt clutch mech if that makes a difference.
Posted : 24/10/2014 10:17 pm
@ Lazy Mike
Hmm, makes sense when you put it like that. โ“
Easy to check since the chain will be split anyway!
Posted : 25/10/2014 12:50 am
