29er, non-boost 20m...
[Closed] 29er, non-boost 20mm axle front wheel. Any around?
 benz
My search-fu is failing me.
Anyone seen any 29er, non-boost 20mm hub front wheels or are they non-existent?
Looking for a relatively cheap one for an upgrade to my neighbours bike.
Thanks.
Posted : 09/05/2022 5:06 pm
What fork have they got that's 29er and 20mm? Can't it be changed to a 15mm?
What are you looking for by way of an upgrade? 20mm having been dead for a long while any 20mm specific hubs are like to be on an old rim so possibly no upgrade at all. The other option is likely to be a convertible hub such as hope but then it's not likely to be cheap.
Best bet is probably a wanted ad.
Obvious point is obvious but, you know 110mm is normal 20mm width don't you, not boost (though its the same width as boost)?
Posted : 09/05/2022 5:17 pm
 5lab
not really, 20mm is still the standard for any riding that optimises strength over weight, DH and DJ forks are still 20mm.
that said, I can't think of many things that were 29er and 20mm either, other than recent dh wheels which probably isn't what you're after.. something with convertable endcaps maybe your best bet, hope/superstar?
Posted : 09/05/2022 5:21 pm
Probably easiest to build one up with an old 20mm hub as it's a strange combination that you're unlikely to find.
Posted : 09/05/2022 6:01 pm
It's an odd size indeed. I struggled to find one second hand in 27.5 flavour, so ended up getting a new nukeproof horizon v2 from chain reaction.
20mm has generally always been 110mm total width, but you can get both boost and non-boost hubs, which refers to the hub flange spacing and how the brake mounts line up.
A non-boost wheel will work in a boost fork with rotor spacers, but not the other way round. So for 20mm non boost you need exactly that.
Edit: I looked into turning the fork into 15mm but that would need new lowers, or spacers/bushes/inserts thingys but they were strongly advised against. I've seen some people insert them and then use a bolt on both ends of the axel, but that seemed too much of a bodge for me
Posted : 09/05/2022 6:46 pm
It's an unfashionable size so should be a good one to buy used?
Stealth ad obviously but I have a nearly-new WTB Frequency rim on a 20mm DT350 hub spare, it's quite burly and not super cheap but fits the bill otherwise- would be £75
Posted : 09/05/2022 7:18 pm
I built up my horsethief with a 29 flow ex with a 20mm hope hub. The forks were rs revs. This was pre boost mind you, but it wasn't that odd choice iirc.
Posted : 09/05/2022 7:28 pm
Just find one with Hope hub and then buy the 20mm adaptors.
I've an old Flow/Hope in the garage that'll work with any combo QR/15/20.
Posted : 09/05/2022 7:43 pm
