29er Fox 32 with Po...
[Closed] 29er Fox 32 with Post Mount, Hope Mono M4 Post mount caliper - what disc size ?
Just wondering if anyone could confirm what the disc size would be with the following ...
2011 29er Fox 32 RL forks - Post Mount
2007 Hope Mono M4 - Post Mount
Mounting direct without any adaptors, pretty sure it'd be 180mm, but want to make sure.
Posted : 13/09/2013 6:16 pm
 P20
I've bad them both 160 and 180. Is the main piston mainly behind the level of the post mounts? If so it's probably 180
Posted : 13/09/2013 6:24 pm
160 I think, got two F29's and they're both 160mm with various PM brakes, Hope, Shmano, Formula, the 07 M4 is a standard PM caliper so that's what you'd end up with I reckon..
Unless Hope did some weird post mount caliper size..
Posted : 13/09/2013 6:25 pm
Cheers for the info
Posted : 14/09/2013 3:11 pm
