28 tooth cassette o...
[Closed] 28 tooth cassette on 6600 rear mech? - Roadie Content
Tech docs say 27 is max, but general consensus online seems to think that is a conservative estimate.
Anyone actually tried it and did it work. Can't justify/be fussed spending big bucks on a compact right now, so trying to get squeeze additional ratios from the cassette.
Mech is a Ultegra 6600, think its the standard ss model, although it doesn't state this on it.
ta
Posted : 18/02/2013 9:40 pm
Just wind the B-tension screw in.I tend to view shimano's listed capacities as 'guidelines' ๐Ÿ˜‰
Posted : 18/02/2013 9:44 pm
Yep, 28 is fine.
Posted : 18/02/2013 10:17 pm
so how big do you reckon I could go? I notice they sell them in 30s as well!
Pushing it? or will it work if I jiggle with the limit screws?
ta
Posted : 20/02/2013 9:19 pm
I run a 32 as an off-road alternative on my Frankenbike. No mech/spoke interface yet - just avoid shifting too low down the block when you're in the big ring.
Edit : Same mech BTW, with a 53-39 CS
Posted : 20/02/2013 9:34 pm
web wisdom says 28 is max. apparently its the fact that the mech can't clear the cassette. is your mech 6600ss teasel? I'm tempted to give it a go but can't be assed ending up with a 50 quid cassette I can't use.
and what happens when you do shift to far down the block in big ring?
Posted : 20/02/2013 9:52 pm
Dunno, but I imagine it wouldn't be pretty.
I'll take pic tomorrow in the the lowest gear so you can see the set-up for yourself. Watch this space...
Posted : 20/02/2013 9:56 pm
I think it's the overall capacity you have to watch for.
The 6600 is 29 teeth IIRC, so your front teeth difference is 14 (53-39) and your rear 16 (28-12?) so your total capacity is 30 so only 1 over?
I had a problem recently when I tried to put a 11-28 with a 50-34, total capacity was 33 and the mech couldn't take up the slack in the chain when on small chainring and small end of the cassette ๐Ÿ™
Posted : 20/02/2013 10:18 pm
Okay - as promised, here are the pics. A 6600 mech with a 32t block. No shifting issues whatsoever. No dropped chain, either.
39t chainring...
53t chainring...
Posted : 21/02/2013 7:57 pm
Just fitted one to my roadie tonite, seems fine. Granted I left the chain a link too long, but that's easy to sort.
Shifts up & down the block easily with a short 105 mech on 50/34 front.
Posted : 21/02/2013 9:41 pm
thanks teasel, is that defo the ss verion of the mech? Steve, what mech were you running? Is it a 30 tooth you fitted?
may give it a go...it appears to work.
Posted : 21/02/2013 10:10 pm
Yessum
Posted : 21/02/2013 10:49 pm
As far as I know it's the SS mech, I've fitted a 28t but don't see any reason why a 39t won't fit
Posted : 21/02/2013 11:40 pm
there is no universal answer because dropout lengths are, surprisingly, not all the same.
28 is usually doable though, with a tension-screw tweak, but any more teeth is pushing it. Some people get 30t+ without jockey rubbing but I've had frames where 27t is close. Chain length helps obviously, as a short chain pulls the mech arm forward, freeing up more clearance.
The newer mechs (6700, 7900 etc.) have more clearance so are officially good for 28t.
Posted : 22/02/2013 9:21 am
Tick
Posted : 22/02/2013 10:19 am
Reggiegasket is right. For example, at the 3 Peaks, I used a 12-36 cassette with 39/46 rings and a 6700 rear mech. No problems at all. I must have an extraordinarily long hanger. If you'll pardon the expression.
Posted : 22/02/2013 10:42 am
If you have trouble clearing the bottom gear, say when maxing it out to 32, you can get a 10t pulley top cog to replace the stock 11t one.
With some care about the chain length it should work. Big-front to big-rear is not a gear you want to run a lot anyway.
Posted : 22/02/2013 11:19 am
