26 tubes in 29?
[Closed] 26 tubes in 29?
Before I commit to summer tyres I will run them with tubes rather than going tubeless straight away.
29 tubes cost a lot more than 26 . So can I run them , and if yes should I go thicker than normal?
Posted : 21/03/2012 7:53 pm
No. 29" is essentially a 700c wheel with a wider rim.
Posted : 21/03/2012 8:02 pm
Yes you can run them but they are a tight fit. I've not done it personally but my mate has.
Posted : 21/03/2012 8:14 pm
 JRTG
Yep they fit fine. Always carried only 1 tube on my trek 69er as a 26 will easily stretch and I'd fold a 29er tube. If 29er folded being lumpy is an issue, mtfu.
Posted : 21/03/2012 8:32 pm
yes, they're fine. I did it for a few months and while it's a bit trickier to get them in they work perfectly well.
Posted : 21/03/2012 8:57 pm
yep work fine no problem ๐Ÿ˜€
Posted : 21/03/2012 8:59 pm
Definitely. Got them in both front and rear on mine. FWIW part inflating them makes them easier to fit.
Posted : 21/03/2012 9:24 pm
Never used 29" on mine, but planning to get just one to stick in the camelbak as a spare. Only reason being trying to fix a flat one freezing night a few months ago, & trying to stretch the tube to get it in was just an added faff at the trailside. But it was cold. I really I should just MTFU shouldnt I... ๐Ÿ™‚
Posted : 21/03/2012 9:57 pm
i just use 26 yeah - but it is an arse when you get a puncture in the ice.
Posted : 21/03/2012 10:10 pm
I always mount my tyres motorbike stylee. Inflate tube a bit put it in tyre then stick on wheel. No twisted tubes or pinches.
Posted : 21/03/2012 10:15 pm
another yes from me too. part inflate first.
bit of a necessity as it is still hard finding them.
works better than 700c ones.
Posted : 22/03/2012 6:51 am
