26" mtb mutate...
[Closed] 26" mtb mutated into a gravel/cx bike, will I die?
So I've got most of the parts together to rebuild my On One 456 hardtail, but I'm intrigued by gravel/cx bikes and wonder whether I can bastardise my owd hardtail to create a cx bike of sorts. I've checked and my roadie wheel (700c) fits in the stays with decent clearance, some slightly bigger nobbly cx tyres should fit too. Thinking of adding a set of drop bars, and some disc brakes (mounts obvs present on my hardtail frame), and a rigid fork with brake mounts also, and I should be away. Can anyone see why this wouldn't work? Any chance of death?
Posted : 20/01/2017 3:21 pm
Unless it is 2 sizes too small for you as a mountain bike, you are going to have too much top tube!
Posted : 20/01/2017 4:23 pm
You'll be fine as a gravel grinder type bike. You can try something like Jones Loops rather than drops if you want more positions
A rigid bike is ideal, and very comfy, for lots of tame tracks/paths
Posted : 20/01/2017 5:56 pm
You should be fine, you might want a shorter TT for drop bars, but then again you might have a shorter TT as it was a mountain bike not a road bike...
Posted : 20/01/2017 5:59 pm
 FOG
I have done pretty much the same with my 26" Soul. All that was needed was a spacer to use my 9 speed block on an 11 speed freehub to enable me to use my spare road wheels. I have not gone the whole hog and fitted drops because I think the tt would be too short and I didn't want to buy drops compatible shifters and brake levers. I am still using 25mm road tyres but the next step is to get some cx tyres . It makes a great gravel bike and is ideal for a bit of bike packing
Posted : 20/01/2017 6:29 pm
Just depends on how much reach you want or are happy with
I nearly did this rather than buying a bike. he top tub on my Orange Gringo would have been fine for me as it is old enough to date back to long stems
Posted : 20/01/2017 7:16 pm
Do the axles fit?
I'd considered doing this once nd thought that road bikes ran 130mm not 135mm on the rear and assumed the front was also different width?
Posted : 20/01/2017 7:21 pm
 PJay
Excellent, thanks all so far. FOG I'm glad I'm not the only one to have considered it, and bikepacking is the eventual aim. Flat bars sound like the general concensus, but being a lanky bugger, I might get away with it. I'm 6'4" and my 456 is a 19" frame. I've got both in the spares pot so I'll see what works, but I do like the idea of a hassle free flat bar, less new parts to buy, and I guess better braking modulation with hydraulic disc brakes vs mechanical cx disc brakes?
Posted : 20/01/2017 8:03 pm
I built this last year. I just kept the 26 wheels with 1.75 tyres.
She flew ๐Ÿ™‚
Posted : 20/01/2017 8:05 pm
I always find the TT too long but did use one with narrow straight bars and Cinellu Spinacis.
Posted : 20/01/2017 8:11 pm
You could even stay 26 and get some suitable tyres....?
http://www.islabikes.co.uk/products/accessories/tyres/item/26-islabikes-greim-cyclocross-tyre-price-per-tyre
Posted : 20/01/2017 8:25 pm
Short stubby stem is all you need...my swift is now on drops and I love it
Posted : 20/01/2017 10:50 pm
