20mm revelations si...
[Closed] 20mm revelations similar to older pikes?
i had a set of 05 coil pikes ont he yeti 575 07 frame, i liked them. Just bought some fox 36 talas r alittle impulsive, they look the business but may be overkill fo the bike. considering a set of the 20mm bolt thru rev's as they are 800gramms lighter (at least) than the fox's and pikes were but appear on the surface to do exactly the same job as the pikes did. Are theyas stiff etc??
anywhere know the cheapest place for them online
thanks
Posted : 03/03/2009 12:39 pm
I bought my 20mm revs from Merlin just before Christmas, got a good deal and I think they are some of the cheapest around - great forks. However, I think prices have risen throughout the UK since the New Year.
Would you consider swapping for your Fox forks?
Posted : 03/03/2009 12:47 pm
would you consider selling your fox forks? They are just what I'm after!
Posted : 03/03/2009 12:53 pm
Not as stiff as Pikes imho but obviously a bit lighter.
open to opffers for selling or swapping fox's 06 slight cable rub on crown, otherwise just about unmarked steerer is a smidge under 200mm
martin_varey@yahoo.com
Posted : 03/03/2009 1:00 pm
spacecadett the white ones or silver??
Posted : 03/03/2009 1:01 pm
White. Dual air 20 mm. Not the U-turn models.
Posted : 03/03/2009 1:35 pm
