20mm Maxle thingies
[Closed] 20mm Maxle thingies
Hokay, this may be awkward without pictures.
I have just bought a Rockshox Pike with a 20mm Maxle thingie.
In my shed I have what I believe is a standard 20mm wheel.
I have removed from the wheel a threaded axle adaptor thingie which takes what seems to be a fairly standard type cam QR preumably for open dropouts which came with the wheel. The maxle now fits through the hub body, but the hub shell is a good bit narrower than the distance between the dropouts. The wheel can therefore slide from side to side on the Maxle.
Is there a thingumabob or a widget of some sort that I need to buy to make it all work, or have I simply managed to have entirely the wrong sort of wheel for the job?
Thanks for your thoughts.
๐Ÿ™‚
Posted : 25/04/2009 12:46 pm
What hubs are you using? When I converted my Hope Bulbs, they came with a couple of spacers that fit either side that fill in the gaps.
Posted : 25/04/2009 12:51 pm
Sounds like you need some spacers or adaptors each side
Posted : 25/04/2009 1:11 pm
