Has anyone seen any info as to what a 370s hub is?
Looking at a set of 2022 wheels (catalogue so no web info) and it lists the hubs as "370s"
It does not specify is its star or 3 pawl so I'm unsure what the "s" denotes.
As a complete guess it's probably some OEM hub that differs slightly from a standard 370 that works better as part of the wheelset, or can be delivered at a slightly lower price point. I doubt it's got a Star ratchet because then they'd call it 350.
Possibilities:
S = straight pull (spokes)
S = Steel free hub (cheaper / heavier maybe)
370s or (OEM 360s) are 3 pawl. If you can find one in stock you can buy the ratchet upgrade for £80
That makes sense, but I've found 2 bikes with this wheelset and the bike specs describe it as ratchet hubs.
None the wise and perhaps catalogue errors
If it’s 2022 kit, the 370 shoul,d use the new budget ratchet set up.
