I recently bought this second hand and the cranks have a bit of play which I'm guessing means it needs a new bottom bracket. I'd like to order one before I remove the chain set but I haven't been able to find any info on what I need. I'm guessing press fit??? I think it's an xt chainset but there's no obvious signs and I haven't taken a close look yet.
Posted : 25/06/2024 8:39 am
I have an earlier model that uses a standard 89.5mm/92mm press fit like this one
Not sure if the changed the size when they updated the frame though.
Posted : 25/06/2024 11:29 am
If it's an XT crank (which you say it is) and pressfit (which Cubes are), then any BB89/92 BB will fit.
Posted : 26/06/2024 8:49 am
Cheers.
Posted : 26/06/2024 12:07 pm
