2018 soul parts to ...
[Closed] 2018 soul parts to a flare max frame?
How would they transfer over? Wheel size wise mainly?
Posted : 12/06/2019 11:36 am
Assuming the 2018 Soul is the current Mk5 (and so Boost) then everything should fit just fine.
Running 27.5 wheels on a bike designed for 29 and Plus is going to drop the BB a touch but it won’t kill you. Stick 2.5/2.6’s on and you’ll probably not even notice.
Posted : 12/06/2019 11:41 am
 cy
If you're looking to go to a droplink bike from a Soul, the bike you need is the Flare, not the FlareMAX. The FlareMAX won't work at all with 27.5" sized forks and wheels, but the Flare will just need a new zero stack top cup and every single bit of kit off your Soul will transfer across.
www.cotic.co.uk/product/flare
Posted : 12/06/2019 12:46 pm
I would suspect that your rear brake hose wouldn’t be long enough.
I’m a running an uncut (1700mm) slx on the FlareMAX. The one off a SolarisMAX was too short (it would’ve pulled out of the lever on a hard right...).
I’d imagine soul to flare would be similar...
Posted : 12/06/2019 1:01 pm
Good point on fork. Hadn’t spotted that, it’ll affect the set up too.
It’s worth pointing out Cy is ‘Mr Cotic’ so he probably knows better than us.
I think it’s a bit strong saying it wouldn’t work at all, but Cy’s 100% right that if you have the choice then the regular Flare is a better solution. 27.5 forks and wheels on a 29er aren’t really ideal. If you found a set of suitable lowers for the forks that would fix them as a problem, the uppers would switch in as easy as doing an oil and seal service.
Posted : 12/06/2019 3:55 pm
Also worth noting that droplink Bikes are 1x only (nowhere for a front mech). I run boost chainset (with a 30T, not sure if that’s obligatory or not).
Posted : 12/06/2019 4:09 pm
I think it’s a bit strong saying it wouldn’t work at all…
Putting that kit on a current FlareMAX will put your pedals so low it'll be unrideable. Will work perfectly on the new Flare, as Cy says.
Posted : 12/06/2019 4:10 pm
Bugger. Cant afford a flare frame new. And used they're very rare.
Posted : 12/06/2019 4:39 pm
And used they’re very rare.
<Looks confused>
Posted : 12/06/2019 4:52 pm
<Looks confused>
There's a Flaremax for sale on Facebook, frame & shock for a bargain price. This post appeared slightly after I saw the advert, I imagine the 2 are connected.
Posted : 12/06/2019 5:10 pm
The new LS geo Flare frames (made in Scotland) are only just recently released, no?
I'm pretty sure theres a longstanding thread called wheres the new Cotic Flare coming (or something)...
Posted : 12/06/2019 6:17 pm
 cy
Yes, Flare in the latest guise has only been in production for about 3 months. The previous pre-Longshot version was around for a fair while. Another option to look at for swapping things over if you can't stretch to buying new would be looking out for a 2018 onwards Longshot geometry Rocket. They have been in production since February 2018. With a 140mm fork, and maybe invest in a shock service and get the shock stroke reduced to 50mm (from 57mm) you'd have a 140 front/135 rear bike with cool handling. It would be a right laugh. As per my post above, you'd need a ZS top headset cup and everything else would move over perfectly.
Posted : 13/06/2019 1:01 pm
 cy
If you are seriously looking at that FlareMAX you really would need 29er forks at the very least. It would run OK with 27.5 wheels if you put big volume 2.6 or 2.8 tyres on it (MAX is short for Maximum Versatility - it can run 29er or 275 Plus), but you really would need to put some proper length forks on it to get the geometry running properly.
Posted : 13/06/2019 1:03 pm
Cheers cy. It's looking like I'll have to shelve the soul frame for a bit and get a FS second hand.
Posted : 13/06/2019 10:00 pm
 wors
I want a flare. In black. It looks lovely
Posted : 13/06/2019 11:20 pm
