2018 Fox Rhythm 34 ...
[Closed] 2018 Fox Rhythm 34 130mm replacement
I currently have this fork on my 2018 Fuel but it has been discovered that the steerer tube is not 100% round. This makes getting the stem and spacers on and off pretty hard and my local mechanic has said this could be the cause of some front end creaking.
I don’t want to spend a huge amount so maybe something used, but other than a direct replacement what other forks are of similar quality? It’s 130mm 29er boost 51mm.
Stock of forks seems limited.
Posted : 15/04/2022 12:42 pm
What length steerer are you looking for
Posted : 15/04/2022 1:38 pm
I have a set of these, and wouldn’t part with them for something else.
How about a new steerer?
https://www.ndtuned.com/en/tubo-de-direccao.php
Pikes
Posted : 15/04/2022 1:48 pm
If you're happy with the performance of the forks just get a new steerer tube pressed in. I had one done on some Fox 32's by RSF in Plymouth as it was cheaper than getting different forks due to the current one being too short for a new frame. He did while I was there, took all of 10 minutes and has been perfect since.
Posted : 15/04/2022 1:55 pm
Bombers
Posted : 15/04/2022 1:59 pm
Pike select+ is a brilliant fork.
But as above, you may be able to get a new steerer fitted.
Try slick and slide, I think they do it.
Posted : 15/04/2022 2:20 pm
RSF can probably fit you a new steerer if there’s nothing else wrong with the fork.
Other than that the obvious choice is a RS Pike.
Posted : 15/04/2022 7:24 pm
