2017 Fox Grip Remot...
[Closed] 2017 Fox Grip Remote lever solutions?
What lever options are there out there? Fox and non Fox solutions? I have a fork but no lever...
Ta ๐Ÿ™‚
Posted : 28/12/2017 12:08 pm
Had any luck with that? Presume it was the fork from bike-components.de - looking at it myself!
Posted : 24/04/2018 10:31 pm
hi there something you may be able to assist me on please @guglielmo I have a pr of fox 34,s with the crown mounted lever
is it right that when in full open it stops on the fork crown and the same when you go for full lockout -there is individual clicks as I go through from open to lockย and there is a definitive click at the half way part but fully open and fully locked out the lever just stops on the fork crown rather than have a mechanical stops as such is this how the grip crown lever works
Posted : 25/04/2018 4:06 pm
Fit4 remotes have their own part number and are available aftermarket. Grip remotes should also be available.
Posted : 25/04/2018 4:21 pm
Same lever for both fit4 and grip for 2pos lever.
There are some 3 pos grip dampers though i believe so you'd need the appropriate # of positions
Installation is different when clamping the cable. Grip was rather fiddly as you have to rotate the topcap to lockout with lever set to lockout while holding cable tension and tightening the grub screw.
Try your fork 4 digit code on fox's site and it will give you specifics and possible part number for lever.
Posted : 25/04/2018 4:30 pm
