2013 Lapierre Spicy...
[Closed] 2013 Lapierre Spicy 916 carbon: Info needed!
Hi all,
I have recently aquired from Hannah, here at Singletrack (for their recent charity fundraising), a 2013 Lapierre Spicy 916 in carbon. It has post mount brakes in the rear and one of the 'threaded barrel inserts' (no idea of their official title) that the brakes screw into is missing. Any body any idea of part number or a source for spares or even size/spec of said item?
So far I have contacted Lapierre UK and Raleigh (I suspect both emails arrived in the same office) and the exploded diagrams they sent do not show the partin question at all!
Anyone with any advice so I can get this built up again.
Thanks in advance...
Posted : 05/08/2021 4:20 pm
A barrel nut? You might be able to use a generic one if you know the thread size etc
Posted : 05/08/2021 5:47 pm
The barrel slots into a hole in the carbon stay and it would be an M6 bolt that secures the brake mount.
I can only find stainless m6 barrels with a 10mm od and that appears to be too big the it's slot!
I can't find m6 nuts in an 8mm od size or find the actual Lapierre part!
Posted : 05/08/2021 6:37 pm
brake mount
Posted : 05/08/2021 6:47 pm
My 2017 identiti mettle uses brake mount barrel inserts. They are easy to find online, and may possible be the same size you need.
Posted : 06/08/2021 8:21 am
Thanks, that definitely looks worth investigating but at first glance look like a standard 10mm od. Will check them out for sure though. 👌
Posted : 06/08/2021 9:51 am
Whytes G160 and T-130 of various models use them too.
https://whyte.bike/collections/parts-accessories/products/post-mount-barrel-nuts
Posted : 06/08/2021 10:05 am
Dammit! In nicer colours too! Suspect these are all 10mm diameter which I think is too big but have ordered some to see...
Thanks you all ๐Ÿ™‚
Posted : 06/08/2021 12:44 pm
