2012 Garmin 800 wit...
2012 Garmin 800 with OS Maps - replacement options
My 2012 Garmin with OS maps is nearing the end of its life. Can I get a Garmin with OS Maps or transfer the OS maps onto another newer Garmin?
Posted : 17/09/2022 10:05 pm
Don’t you just put the micro sd card with the maps into the new Garmin?
I’ve never owned one but I was told to buy an old 800 just for the os maps on the card
Posted : 17/09/2022 10:14 pm
Almost all new garmins come with detailed maps preloaded
Map updates to older devices are still free
https://www.dcrainmaker.com/2019/08/how-to-install-free-maps-on-your-garmin-edge.html/amp
Posted : 17/09/2022 10:29 pm
 PJay
Garmin have always had some odd licencing rules for their maps. If the maps were bought on an SD card then they'll be locked to that card (the card will work on any unit but only off the original card).
If they were bought as a download or came supplied on the unit, then they're locked to that unit and can't be used on others. I'm pretty sure though that there are utilities available that'll remove the protection so that they can be used freely.
Posted : 18/09/2022 9:33 am
Not OS Maps.
Posted : 18/09/2022 9:51 am
The Edge 1030 has a SD tray and will accept the OS maps. From what I’ve read the 1030+ and 1040 don’t take a SD card.
I used the OS maps for a while after getting a 1030 (also changed from an 800) but now don’t bother as the built in mapping I find better.
Posted : 18/09/2022 10:22 am
Thanks for the replies. I was going with the 830 but it has no SD card slot.
Posted : 20/09/2022 8:27 pm
