Could anyone with a 2011 or 2012 Mojo SL or SLR check their Fox Rp23 shock settings for me if poss? Am presuming the compression & rebound tune are both medium,am also after the boost valve pressure setting (psi will be written on aircan). Have phoned 2pure & Mojo but they just said phone the other so trying here now!
As it's a DW-link it would of thought both are low
Bump.
I think your correct with 'medium' tune for both. 175psi is the std. boost pressure.
Have you got a big or a small Air can?
I've found that (especially as the Christmas pies have worked thier magic) the large air can tends to wallow and sit deep in the mid stroke, giving it a crappy feel. For a heavier or aggressive rider of 85kgs plus
Even upping the boost pressure - which I also believe they need, doesn't fix it all...
